Combining 1440 and 1920 Cineform Files at DVinfo.net
CineForm Software Showcase
Old May 22nd, 2008, 02:17 PM   #1
I use ProspectHD and PP CS3 (with a custom preset in Prospect for 1440x1080 for HDV capture from my HV20 in 24F). I just ordered the HF100 and plan to combine my HDV (1440x1080) captures with 1920x1080 AVCHD files from the HF100. (I know I will need to convert them from mts to avi beforehand. I have tried VoltaicHD and Elecard's trial version with mixed results.)
Assuming I can figure out some good mts-avi conversion process, what settings would I use in PP CS3 to combine the two types? I would assume it's ProspectHD 1920x1080. But what will the 1440x1080 HDV captures look/behave like in this environment?
Ed Hecht is offline   Reply With Quote
Old May 22nd, 2008, 03:17 PM   #2
Use HD Link to upsample your 1440 x 1080 to 1920.
Works great.
Christopher Grant Harvey is offline   Reply With Quote
Old May 22nd, 2008, 03:25 PM   #3
Originally Posted by Christopher Grant Harvey View Post
Use HD Link to upsample your 1440 x 1080 to 1920. Works great.
Interesting. I thought HDLink was a capture utility only. I will give it a whirl. I would have captured my HDV files to 1920x1080 (via HDMI) with HDLink and Intensity Pro, but I was getting really annoying AV sync problems in the captured files. Thanks!
Old May 28th, 2008, 05:36 PM   #4
Cineform Live capture
Hi Ed.I found that I had a similiar experience in that the previous versions of the Intensity hardware and Cineform had audio sync problems but I think that if you update to the latest versions from both camps I believe that the issues have been ironed out.I have not had a problem since a few months ago when I updated so perhaps it's worth trying again.
Henry Olonga is offline   Reply With Quote
Old May 28th, 2008, 06:16 PM   #5
Thanks, Henry. It appears Black Magic DID release new software/drivers back in March. I did not have them. I'll have to wait to test til I get my new machine. :(
Just bagged my old P4 and am getting a Quad Core system to edit AVCHD files...
