Thread Tools
Search this Thread
Windows XP 64bit for CS3 with Cineform
Hi there,
I found to need more RAM memory for my new workstation: As Cineform is not supporting Vista for the moment the only option is using XP-64bit. The only problem is, that Adobe officially doesn't support XP-64bit. They only certify for 32bit systems... that worries me, as the Vers. 3.2.0 already has many software bugs on their "certified" system (XP SP2, 32bit) Is there anybody who is running CS3 (production premium suite) succesfully under XP-64bit ? What is your experience ? Would like to know, before investing in new infrastructure... Thanks for any advice. Ulli |
Internally we're running XP64 regularly with CS3 and Prospect 4K plus a Xena card. We made some modifications to the way the CineForm codec is called which can benefit from the larger address space in XP64 even though the individual apps (CS3 and P4K) are each 32 bits.
I'll admit that we have not done comprehensive testing across all our products to verify XP64 functionality, but because all CineForm products derive from a similar code tree I suspect you'll be fine with CineForm products with XP64. I can't vouch for Adobe of course, but CS3 seems to be working fine for us in XP64. |
David, is there any meaningful increase in performance from 64bit over 32bit?
In say FCP vs Premiere + Cineform? |
We run both OS's side-by-side (in different workstations). No probs and the x64 seems to "do it better"!
Haven't found any situation yet that caused probs for CS3 on the x64 ws, but only benefits. In fact, 32bit gives us more trouble overall. We plan to switch both ws's to x64, if that's any indication. And yes, Christopher, with AE especially, there is realworld benefit. |
#5 |
Call me an oddball, but I'm running Vista 64 with CS3 and AspectHD. Cineform advised against Vista 64, but it's just so much more stable on MY system vs WinXP on the same computer. I just edited a short 4 minute CFHD sequence and burned it to BD-RE using Encore...plays great on my PS3.
The only "glitch" (if you can call it that) is that there's a couple seconds of lag from the time you press the space bar to the timeline playing back. I'll take that any day over the random freezes and sudden quits to the desktop that I was experiencing in XP. Drew |
#6 |
Drew, are you using SP1? We've heard from some users that SP1 is much more stable.
#7 | |
In the meantime I heard from a local friend running CS3 on XP-64 without any problems... Fine ! Ulli |
#8 |
David: My initial install of all the software and drivers was pre-SP1 (because I read somewhere that after SP1 you cannot install unsigned drivers...don't know if it's true, but I didn't want to chance it). Then I updated to SP1 before editing.
Ulli: If I had a choice between running XP64 and Vista64, I probably would choose XP64 only because Cineform has recommended it and they've tested with it. Since I already bought Vista64 (and since I was having a lot of stability issues with XP32), I had no choice but to install it and see what happens. It's not perfect since I've had one or two freezes, but it's much more stable on my system...stable enough for me to complete this HD project hopefully. Thanks, Drew |
