PHD Problem in the last 2 recent Builds. at DVinfo.net
CineForm Software Showcase
Old May 14th, 2008, 09:23 PM   #1
Ok cineform
After a long research, I found that the last two builds for PHD are containing a bug with the (fade in) and (fade out) of text, footage, and other effect like text shine.... MBullet...
Premier CS3
(I tried different CS3 updates and is the same issue in all of them)
Now Cineform
(Testing the same time line with all this effects in the same project.)
Installing Build164 and build159 I have issues with the combination of opacity text and footage fade in/out shine text.( The main problem is when the exported file is coming out like none of this effects were applied but before the export process the program monitor shows all of them ok when you move the cti cursor)
After installing the build 154 they are working perfect with the same timeline.
Going back to the installation of the recent builds I have the same problem again.
The sad part is that the build 154 is the version not working with TMPGENC Express.
This issue is a constrain for the work that Im doing in this past couple of days.
I will open a Ticket also
Jose Ortiz is offline   Reply With Quote
Old May 15th, 2008, 09:44 AM   #2
CTO, CineForm Inc.
Good detailed bug report, now fixed (will be in 3.3.1.) This is an old issue that Premiere sometimes sends data without pre-multipling the alpha channels (the AME often has this issue.) However there is a simple workaround: In the CineForm HD Exporter, under Compiler Settings where you set quality, turn on the threading. Now exports and renders will be fine.
Old May 15th, 2008, 10:46 AM   #3
Thanks David
Prospect Hd is $1000.00
Cineform service "Priceless!"
I also can not wait to make the invesment of the CF video recorder in the near future.
