RGB parade and Maximum Bit Depth with AspectHD at DVinfo.net
CineForm Software Showcase
Old May 12th, 2008, 11:59 AM   #1
Hi,
I'm trying to color correct using RGB parade in Premiere CS3 but can't recover clipping in whites even with Maximum Bit Depth enabled (the choices sub-menu stays grayed even when I click in box to enable it).
Is it a bug or something standard in AspectHD (I got v5.X build 115) ? If so is there a workaround (an efficient one) ?
Thank you.
Frederic Leclair is offline   Reply With Quote
Old May 12th, 2008, 12:05 PM   #2
CTO, CineForm Inc.
We don't support Maximum Bit Depth (32-bit float) in Aspect HD, as it is an 8-bit only product. For 32-bit float you need our Prospect level product.
