Deactivate for upgrade from Prospect to 2K?? at DVinfo.net
CineForm Software Showcase
Old May 10th, 2008, 01:09 PM   #1
Do I need to deactivate Prospect before I load in Prospect 2k ???
Old May 10th, 2008, 06:57 PM   #2
CTO, CineForm Inc.
If you have gone the upgrade route then you likely need to deactive your old license to get the new one.
Old May 11th, 2008, 09:17 AM   #3
Just for clarification, you actually do NOT need to deactivate before you can activate P2K, but your old S/N will be "locked" so it cannot be activated again.
But you do need to uninstall the "old" software before installing the new software.
David Taylor is offline   Reply With Quote
Old May 12th, 2008, 04:34 AM   #4
Ok, Thanks for the quick response...
Old May 12th, 2008, 03:09 PM   #5
Just got back from Natal and I just did as you mentioned, David (T) and though the Prospect HD on this particular ws seemed to upgrade normally to Prospect 2K, now HDLink won't run and crashes.
(I did at least unload HD before loading the 2K. I honestly forgot to deactivate the HD first...I confess...)
Still seems to capture in PP CS3 okay, but HDLink 2K is unusable. Seems like the two got confused somehow.
Suggestions?
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old May 12th, 2008, 03:35 PM   #6
Stephen, that's unusual behavior. I recommend uninstalling all CineForm software, reboot, then reinstall P2K. If your problem persists then file a trouble ticket.
Old May 12th, 2008, 04:11 PM   #7
It's healed!
Thanks...sorry, I should have tried that first...
