Intensity as video mixer? at DVinfo.net
CineForm Software Showcase
Old May 6th, 2008, 07:21 PM   #1
Had a problem today.
I was shooting a video with my self-built Wintel PC + Intensity to capture into Aspect HD from Sony V1U's HDMI out.
I needed to position people/objects exactly the same way they were in the previous day's shot.
Have read about Intensity on-air, but did not have the time to investigate more - like whether it actually supports an image instead of a second video feed.
Basically I need a very simple WinXP-based mixer that would allow me to mix between the live feed (HDMI or firewire) and a static image file.
Image filer is a video cap of the previous day's disposition, which must be matched.
I thought, by using 50% transparency, I'd be able to see through the image, position people and things to match perfectly, and continue shooting.
Possible? With or without Intensity?
Is there a better way to approach this issue?
Alex Raskin is offline   Reply With Quote
Old May 8th, 2008, 03:53 AM   #2
Hmm.. I think Adobe's OnLocation would be much better
Anton Galimzyanov is offline   Reply With Quote
Old May 8th, 2008, 08:44 AM   #3
Anton, thanks for the suggestion!
I used to own DV rach + HDV patch, but it was a couple years ago when they did not have Onion Skin mode, I believe.
in any case, I think OnLocation/DV Rack won't work with HDMI as video signal source?
