Question for Cimeform/Ppro Cs3 Users. at DVinfo.net
CineForm Software Showcase
Old May 4th, 2008, 12:50 PM   #1
In the most recent builds from prospect HD I noticed that sometimes that I combine a Magic Bullet Filters with chance in % of Opacity in the timeline I'm not getting the desired results on the exported File.
Example
Is avoiding all the opacity changes in the text or timeline instead of doing the opacity changing gradually.
Trapcode shine filter in thex is not comming right. Is comming with weird colors.
When I move the CTI in the time line before exporting everything looks fine on the program window. When I export then is the issue.
I export all my files as (CF avi Hight optimized quality with interlaced check mark on also.
Any Ideas? Any body experimenting this too?
Jose Ortiz is offline   Reply With Quote
Old May 6th, 2008, 09:14 PM   #2
Make sure you have Black Video under the clip if you're altering Opacity or you have Titles. This may help - if not, try removing MB filters, then re-adding.
I have Aspect HD and have seen this problem when fading in a scene.
Doug Turner
http://therunsmovie.com
Douglas Turner is offline   Reply With Quote
Old May 14th, 2008, 07:57 PM   #3
Sorry Douglas for not responding. I am just returning from out of town.
I was trying every trick possible and I don't find any way to fix this issue.
I can not imagine other users not experimenting this issue.
I will be installing a previous premier version to see if can eliminate this problem.
Old May 14th, 2008, 09:01 PM   #4
Ok I found that this is a bug from the last two recent builds in PHD.
If I install Build159 works fine then in I install The last two builds and I export the same time line the errors are back.
The sad part of this is that this 159 build does not work with TMPgenc epress.
I will let Cineform people know.
