New beta builds for NEO, Aspect & Prospect at DVinfo.net
CineForm Software Showcase
Old April 23rd, 2008, 10:53 AM   #1
CTO, CineForm Inc.
Here are the new 3.3 beta version of all our products. Prospect 4K 3.3 was used extensively at NAB and it held up well.
Changes:
For Prospect 2K & 4K and NEO 4K only
• SetActiveMetadata utility replaces the old RAW control scripts for disabling the 3D LUTs.
• CineForm RAW now has a separate color database (2K and 4K only,) controlled using SetActiveMetadata. There color databases are enter-changeable to allow multiple color profiles between projects. They may also be export and moved between PCs (and soon Macs.)
• The File Metadata RAW controls now support Pick White style white balancing.
• Look compiler, 3D LUT exporter under export Movie (32-bit filters stacks only.)
For Prospect HD/2K/HD
• Support for 444 exports in BGRA 32-bit float, for SA Color Finesse compatibility under Premiere. Upgraded Dissolve, and flips to use RGB 32-bit float for Color Finesse.
• Add a preview indicator for 32-bit float, vs 16-bit or 16-bit filter stacks.
• Fixed non-square pixel exports from Prospect HD/2K/4K.
For Aspect HD & Prospect HD/2K/HD
• Added a switch in the AVI/MOV export movie other to enable threading. Due to Premiere’s low memory issues, this disabled by default, but should accelerate HD exports for simple projects.
• Scrubbing should be a little faster
For everything
• CFRepair utility now shipped as standard. Primary for repairing files used in live capture, and a power outage or crash left an incomplete AVI.
• HDLink has improved support for AVCHD support, looking for common third party components like the Haali Media Splitter and the CoreAVC decoder, fixing issue where there where too many AVCHD components installed. More information here : http://www.cineform.com/products/Tec...Conversion.htm
• Many internal upgrades.
Here are the download links.
AHD http://www.cineform.com/downloads/As...114-080422.zip
PHD http://www.cineform.com/downloads/Pr...163-080422.zip
P2K http://www.cineform.com/downloads/Pr...163-080422.zip
P4K http://www.cineform.com/downloads/Pr...163-080422.zip
NEO 4K http://www.cineform.com/downloads/Ne...163-080422.zip
NEO HD http://www.cineform.com/downloads/Ne...163-080422.zip
NEO HDV http://www.cineform.com/downloads/Ne...163-080422.zip
If there are no serious bug reports, these will become our release versions soon.
Old April 23rd, 2008, 02:24 PM   #2
Thanks David!
Christopher Grant Harvey is offline   Reply With Quote
Old April 23rd, 2008, 05:18 PM   #3
batch is healed
I've got to hand it to you guys, you've some of the best problem solvers in the business!
Our batch capture woes were healed with these new 3.3 updates and I liked the new additions...
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply
