Aspect HD and converting 1920x1080 at DVinfo.net
CineForm Software Showcase
Old April 21st, 2008, 03:34 AM   #1
I have some rendered CG at 1920x1080p I have tried to convert this in HDLINK under Aspect HD but it doesn't works stalls on 0%. Can I confirm Aspect HD will not ingest input above 1440?
Deniz Ahmet is offline   Reply With Quote
Old April 21st, 2008, 08:38 AM   #2
CTO, CineForm Inc.
Should do if you scale to 1440x1080 in the Prefs. If not, send a small sample to support.
Old April 21st, 2008, 11:07 AM   #3
In the worst case scenario you could simply rescale it to 1440x1080 in VirtualDub using the CineForm HD codec and the resize filter (with Lanczos scaling). It'll take longer to finish and the filesize will be larger than if HDLink were to handle it, but it's a foolproof back-up method.
If your source is fully uncompressed 24-bit or 32-bit RGB CG, you could use Neo 2K or Prospect 2K to convert into CineForm 4:4:4, or 4:4:4:4.
Company Website: Digital Foundry Ltd
Video Games HD Blog: Digital Foundry@Eurogamer
Richard Leadbetter is offline   Reply With Quote
Old April 22nd, 2008, 08:50 AM   #4
David, does that mean this information on your website is wrong?
http://supportcenteronline.com/ics/s...asp?deptID=614
Don't see 1920 listed there...
Old April 22nd, 2008, 08:59 AM   #5
CTO, CineForm Inc.
Link in our old suport site don't work, one reason we stopped using it. I have no idea which you are pointing to. As for 1440 vs 1920 capture, why worry, it works on both PHD and AHD products, scaling if needed.
Old April 22nd, 2008, 09:15 AM   #6
So you mean I can import 1920 into an AHD timeline directly? No quality issues? wow
Old April 22nd, 2008, 09:19 AM   #7
CTO, CineForm Inc.
If you capture a 1920 source directly into AHD, it will scale to match it license.
Old April 22nd, 2008, 09:51 AM   #8
What I want to do is basically render my CG (in ParticleIllusion) and I then export at 1920x1080p AVI uncompressed. Then I planned to convert with HDLINK into 1440 AspectHD- retain the master.
This isn't working for me. I am forced to export directly into CineformHD codec at 1440i from PI.
Old April 22nd, 2008, 09:58 AM   #9
CTO, CineForm Inc.
The results are the same, as 1440x1080 encoded CineForm file. For converting your 1920x1080 uncompressed sources to a 1440x1080 CineForm AVI use a tool like VirtualDub.
