Thread Tools
Search this Thread
Export to tape w/ CS3 & Aspect HD 5.2 working?
I film a lot of hdv footage with a Sony FX-1 that I edit with Premiere Pro CS3 and Aspect HD 5.2. I have an edited movie on the timeline that I need to export back to mini-DV tape. I read on the forum history that there were several workarounds, but what is the latest and best solution?
I tried to just select export to tape in P Pro from the timeline and it asked me if there was a previously exported transport stream that I wanted to export and when I selected no (or cancel, I can't recall) it popped up a HDV Transcode status window and started to transcode to hdv, I assume in preparation to print to tape in my Sony HDV deck. Is this the easy way to do it now, or is this a seemingly correct solution that is ultimately going to bomb out on me? I read some other solutions a while ago that suggested export to CFHD AVI then import that into a native Premiere Pro project, and then export to tape from there as a workaround, but I hope that the above effort I described is actually working feature now! |
CTO, CineForm Inc.
No more work-arounds.
File -> Export Movie the select CineForm M2T. It will produce an M2T that you can load into anything that plays out to your HDV camera/deck. You load it into HDLink and export to your camera from there.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
I used File -> Print to tape and it automatically transcoded to hdv as I described above and it then automatically activated my Sony deck and seems to be recording to tape directly from the Premiere Pro timeline, no HD Link involved! Isn't this even easier? (I will know if twenty minutes or so if it actually works...)
#4 | |
I can't believe that more people aren't talking about this option! If it works it saves a step by avoiding exporting to m2t and then going to HDLink and doing the export to tape from there, right? |
#5 |
CTO, CineForm Inc.
I just prefer the Export movie option as you don't need your camera hooked up during the M2T render. With a long render some cameras will time out, whereas the export movie option works everytime.
#6 | |
But one new client wants the edited movies on mini-DV tapes. This newest version of Aspect HD with Premiere CS3 exporting to this deck straight from the Premiere timeline is the best solution for me now. Very simple and it even saves the transcoded m2t in case I need to do something else with it. Glad to know HDLink is another option. Finally I feel Aspect HD is really integrated fully into Premiere Pro. |
#7 |
I've actually done this both ways and both seem to work fine. I don't use HDLink but when you ask Premiere to Export to Tape it will ask you if you want to use a previously recorded file. That's where I point it to my already-rendered m2t.
One thing I've learned is not only to build in about 5 seconds of black on my timeline before the sequence actually starts, but also to use the "Delay Recording" option in the export box. I usually set it to something like 1200 quarter frames. |
#8 | |
#9 | |||
I also pre-record about a minute or two of black on the tape. You can also insert bars and tone as well as universal counting leader to the head of your project in Premiere if you want to look really professional... |
#10 | |
