Convert Cineform to Divx possible? at DVinfo.net
CineForm Software Showcase
Old January 28th, 2008, 01:21 AM   #1
Captured to Cineform 2k.
Trying to export directly from After Effects CS3 8.02 -> Divx makes AE crash.
Exporting to Cineform from AE and the try and convert the .AVI-file with Divx Converter: Divx says "Invalid Video Stream"
How can I best convert/export a Cineform project to Divx?
/Jocke
Joacim Boive is offline   Reply With Quote
Old January 28th, 2008, 05:33 PM   #2
You could try exporting the AE project to a cineform avi file, and then convert that to divx with whatever you have handy - Premiere, Virtualdub, etc.
Old January 29th, 2008, 03:17 AM   #3
I've tried that:
"Exporting to Cineform from AE and the try and convert the .AVI-file with Divx Converter: Divx says "Invalid Video Stream""
I haven't tried taking the AVI into Premiere, but i seriously doubt it helps since AE crashes when trying just that and that Divx Converter doesn't recognize the stream.
Other ideas?
/Jocke
Old January 29th, 2008, 06:51 AM   #4
If your plain CHD avi files are crashing other applications, I would suggest deinstalling/reinstalling Prospect before you proceed further. (Unless there's some sort of 10-bit vs 8-bit issue going on...?)
Old January 29th, 2008, 03:38 PM   #5
It is obvious that the most recent builds of Prospect are having crashing problems with third applications and the avi CF files.
I am experiencing that issue with the TMPGENC software too. My work around so far is converting with HD link the avi file to mov. Then your file should work.
Jose Ortiz is offline   Reply With Quote
Old January 29th, 2008, 05:37 PM   #6
CFD CINEFORM TO DIVX
Been using TMPG 4.0 EXPRESS for more than a year encoding CFD PROSPECT
FILES TO Divx - Zero Problems . Time after time.
Herman Van Deventer is offline   Reply With Quote
Old January 29th, 2008, 05:42 PM   #7
Me too. but not with the last build in Cineform.
Please report if works for you now with the most recent version of prospect.
Old January 29th, 2008, 05:54 PM   #8
Jose / Iam workink with Prospect 3.2.1 build 145.
I prefer working with the secondlast updates on all my software, just in case
there's a glitch in the latest version.
Otherwise i will check on the forum feedback of latest update loaders before installing the latest build.
Old January 29th, 2008, 09:32 PM   #9
There you go.
I was an Aspect Hd user at that time so I don't have a back up of that version.
Old January 30th, 2008, 04:59 AM   #10
I've tried converting CF Avi -> Mov and then convert that, same issues.
I'll give TMPG a go and post the results.
/Jocke
Old November 20th, 2008, 11:39 AM   #11
What's the latest on this?
I also stumbled with Cineform to DivX conversion, Divx Converte gives "Invalid Video Stream" error and cannot proceed.
How to fix this?
Alex Raskin is offline   Reply With Quote
Old November 20th, 2008, 12:28 PM   #12
Actually, never mind - TMPGEnc 4 Express does wonderful DivX video encoding out of Cineform files.
