Prospect HD B103a conflict w/TMPGEnc 4 at DVinfo.net
CineForm Software Showcase
Old January 14th, 2008, 01:52 PM   #1
I just want to report that the 103a Prospect HD build is not working with TMPGEnc 4. For me and probably some others cineform and this software are part of the HD workflow in order to remove noise and resize Hd footage.
The previous versions were working fine. With this new build you insert the file on TPMG and the footage is shown in rainbow strong colors. You can not even recognize the content in that footage.
I did couple of different things like reinstalling CF and TMPG but no Good results. Any other CF footage captured before this last 103a build still working properly with TMPG. Is something going on in this CF last build.
I really would like to hear from the CF people what could be the problem in this version. For me CF and TMPGenc 4 are my best combination in order to get my final DVD product from HD footage.
Jose Ortiz is offline   Reply With Quote
Old January 14th, 2008, 02:37 PM   #2
CTO, CineForm Inc.
That has been fixed. Contact support. Note: Prospect never had a build number 103a, please give the correct build number to support (that was an Aspect HD build number.)
Old January 14th, 2008, 03:36 PM   #3
Yes David
My mistake the correct build is 150a for Prospect HD and not 103. I got confused.
Any way based in what you said
this specific problem with TMPGenc has been solved?
Im thinking that Im using the newest version but I need to check as soon I got my computer in front. I will be reporting
David
Old January 14th, 2008, 04:44 PM   #4
CTO, CineForm Inc.
We have 104 for Aspect HD user that fixed a progressive decode issue to RGB. And we should will have the PHD fix available later today.
Old January 14th, 2008, 07:02 PM   #5
thanks
that's what I call service
Cineform Rocks!!!
Old January 15th, 2008, 10:56 AM   #6
Any Idea when the new PHD build is going to be available?
Today?
Old January 15th, 2008, 12:10 PM   #7
Jose, the build finished last evening. We haven't tested it internally yet, but it's probably okay. So I'll give you the direct link here: http://www.cineform.com/downloads/Pr...152-080115.zip
After we finish testing later today we'll post it from our site too.
David Taylor is offline   Reply With Quote
Old January 15th, 2008, 12:40 PM   #8
Thanks a lot!
I will be reporting any issue.
Old January 15th, 2008, 07:35 PM   #9
Nop!
This build that you just provide me is still not working with TMPGenc.
Now Is shutting down the program everytime that I want to import the file in it.
I hope that is something easy to fix for you guys.
Old January 15th, 2008, 08:29 PM   #10
CTO, CineForm Inc.
You should contact support then as we aren't talking about he same issue. In some situations a progressively enough image would display in the wrong colors, this has been fixed. No crashes have been reported.
