New Builds for every product now available. at DVinfo.net
CineForm Software Showcase
Old January 4th, 2008, 11:21 PM   #1
CTO, CineForm Inc.
Lot and lots of little bugs fixes, everyone should update.
* Replaced : Neo 2K is replaced with Neo 4K. All Neo 2K customers are upgraded for free to Neo 4K.
* Fixed : Problems with 8-core systems using the CineForm VFW codec
* Fixed : Decoding failure of older CineForm RAW 1080p clips
* Fixed : RGBA32 decodes within VirtualDub
* Fixed : Colorspace was incorrect for progressive RGB decodes in VFW & Sony Vegas
* Fixed : Minor upgrades to the MXF reader
* Fixed : Changing the timecode for an AVIs file in Premiere
* Fixed : (Mac codec) quarter res decoding of CineForm 444
* Added : (Mac codec) scaling greatly improved
Plus a stablity fix for the importer that a few users where hit with.
There is a patch that didn't make the build off time, for Sony EX1 users converting directly form MP4s for use in Premiere (Vegas and other apps where affected.) This addressed some audio popping. This will likely get rolled in to a build 151 sometime next week.
Here is the new patch:
http://www.miscdata.com/cineform/CFM...SourcePush.zip
Install Aspect/Prospect first, then unzip and replace CFMP4AudioSourcePush.ax within C:\Program Files\Common Files\CineForm
Old January 5th, 2008, 08:06 AM   #2
David, the new Prospect HD update link worked fine thru the CF site, but the new NEO4K did not.
I accessed it directly though, and it downloaded correctly, so maybe the site form updater isn't working correctly? I tried it on several different accounts (online and server POP's), so I think it might be messed up for that update somehow. Probably because we are using the N2E, instead of the N4E serial number format to update?
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old January 5th, 2008, 10:55 AM   #3
CTO, CineForm Inc.
Oopps! I will see if we can fix that.
The Trial link for NEO 4K works however, and you can use that for upgrades.
Old January 5th, 2008, 01:41 PM   #4
Where is the link to download the updates?
Jim Gunn is offline   Reply With Quote
Old January 5th, 2008, 01:43 PM   #5
CTO, CineForm Inc.
Same place it always is. Go to www.cineform.com and click on the yellow Downloads arrow.
