Quality of Aspect HD poor? at DVinfo.net
CineForm Software Showcase
Old January 3rd, 2008, 09:42 AM   #1
Hi folks,
downloaded trial of aspect HD and tried it with Premiere 2.0 with two different project settings:
1. cineform 25p (1440x1080)
Quality ok, put preview stutters massively.
2. cineform 50i (1440x1080)
Playback is smooth, but quality is rather poor
Do I do anything wrong?
My config:
Canon XH-A1
Intel Dual core 2
Nividia 7600 GS
2 monitors
HD on SATA
Erich Reisenberger is offline   Reply With Quote
Old January 3rd, 2008, 09:51 AM   #2
Originally Posted by Erich Reisenberger View Post
Hi folks,
My config:
Canon XH-A1
Intel Dual core 2
Nividia 7600 GS
2 monitors
HD on SATA
Did you capture using HDLink or use HDLink to convert the raw MPG files you might have captured with HDVSplit to Cineform AVI files? Does your source match your project settings?
You have more machine then me and mine doesn't stutter. I'm sure that the Cineform Guru's will chime in but this one seems odd.
Miguel Lombana
http://www.miguellombana.com & http://www.phoenixhamradio.com
Miguel Lombana is offline   Reply With Quote
Old January 3rd, 2008, 09:57 AM   #3
CTO, CineForm Inc.
What is your source, 25p or 50i? Set you project to much you footage. Only turn off "de-interlace while scrubbing" and set "Disable preview playback" -- do you observe the same result. Please file a trouble ticket a www.cineform.com/support.
Old January 3rd, 2008, 10:19 AM   #4
Hi David,
Yes my footage is 50i, I did this adjustments as you told me, but it has just brought a little improvement, it plays now a little better but stops after some seconds and then plays again. Quality seems to me as if it was softer then m2t.
Any other idea?
Cheers
Eric
Old January 3rd, 2008, 10:26 AM   #5
CTO, CineForm Inc.
Sounds like you PC is under powered in some way. Please file a trouble ticket and support will confirm whether your system specs are an issue.
Old January 3rd, 2008, 10:38 AM   #6
THINGS IMPROVED!!!
Checked "enable overlay surface" - now it is playing smooth, for 1 sec black screen then comes the image - after 2 sec comes sound as well but sync.
Eric
