Neo HDV, Pulldown and FX1- at DVinfo.net
CineForm Software Showcase
Old October 11th, 2007, 12:04 PM   #1
I touched on this in another thread, but I'm looking for some confirmation of what I actually get.
I have an HV20, and I bought NeoHDV to perform pulldown, and flip functions for on the fly capture. Works great !
I also have and FX1. I've recently shot some straight 60i material on it, and then captured with NeoHDV. I did not disable the pull down, and when I was finished I got a file that had 24p deinterlaced footage. In viewing the footage, it looked an awful lot like similar HV20 24p footage, exhibiting even the same slight stutter effects typical of 24p shooting.
So questions are, 1) Is Neo HDV really usable as a conversion tool for 60i to 24p footage 2) If so, are there situations where its use as outlined will create issues.
Chris J. Barcellos
Old October 11th, 2007, 12:30 PM   #2
CTO, CineForm Inc.
For the FX1 you need to have de-interlace filter checked to get a progressive frame, you should not have this checked for the HV20 (already progressive.) The resolution difference is the FX1 will have a little more motion blur and a little less vertical resolution than the native 24p form the HV20. Also the motion cadence from the FX1 is not quite 24p, under most senerios you willl not see this, yet it makes pans a little more strobey than the native 24p camera and hard for motion tracking effects.
Old October 11th, 2007, 05:05 PM   #3
Okay. Thanks. The shots I had done that with were fairly static. Kind of what I thought if a little more action was going on, that I might see more strobing.
So on HV20 I have had deinterlace box checked thinking it was right because of the "24P in 60i stream" thing. Okay, a new bit of testing for me to try now..
Chris J. Barcellos
