So what am I doing wrong. - Page 2 at DVinfo.net
CineForm Software Showcase
Old December 5th, 2007, 05:46 PM   #16
Thanks for the info. I figured an Adaptec 3-port 1394 board based on a TI OHCI compliant 1394 controller was pretty much a standard configuration for this sort of work, but I'll try some other alternatives as well as other ports on this board.
Are there additional device settings for this card that would help the situation?
Any specific boards you recommend?
Michael
Michael Eskin is offline   Reply With Quote
Old December 5th, 2007, 05:55 PM   #17
CTO, CineForm Inc.
Michael
Most modern (even cheap) Fireware cards seem to addresss the problem. We don't recommend any brand, only changing out from the one you have.
Old December 5th, 2007, 06:00 PM   #18
Will do! Thanks for the advice.
Old December 5th, 2007, 07:59 PM   #19
Swapped the Adaptec out for another NEC-based 1394 board I had, seems to be much better so far. Thanks again for the recommendations.
Old December 7th, 2007, 03:09 AM   #20
this is happening to me as well, my firewire port came with my gateway laptop. I'm also using a cheap 9 dollar fry's firewire cable. Can it be the cable that is causing these drops? I'd hate to have to use a pcmcia firewire card.
Ron Wilber is offline   Reply With Quote
Old December 7th, 2007, 10:43 AM   #21
CTO, CineForm Inc.
It is unlikely to be the cable, particularly is M2T only captures work. CPU load based errors are either the Firewire port or lack of CPU power, with a laptop it could be either.
Old December 7th, 2007, 01:10 PM   #22
It's probably the card. I'm running a 2 giga core2 duo.
So the work around is to use HDVsplit to capture mt2 files without drop out, then use HDlink to convert them to avis. Is there any loss in quality or performance if I do it this way instead all with Neo HDV?
Old December 7th, 2007, 05:20 PM   #23
Ron, no loss of quality at all - just an extra step.
David Taylor is offline   Reply
