CineForm and Sony Vegas 8 - Page 14 at DVinfo.net
CineForm Software Showcase
Old May 8th, 2009, 02:59 PM   #196
Originally Posted by Ivan Seso View Post
Thanks Jon,
So if I have understood you correctly you would:
- render to mpeg2 directly from Vegas Cineform timeline after editing (no need for any additional step here)
- transform original m2t file from cam with HDLink rather than with Vegas (and you can do that even during capturing with average core duo PC)
That is correct...
Jon
Jon McGuffin is offline   Reply With Quote
Old May 12th, 2009, 04:08 PM   #197
Hola, at the end of the game to edit with avi intermediates is the best workflow to keep a good structure of the file(maybe stronger then the m2t)?
I wanna understand if it's suggested to transcode evreytime even if i own a new powerful machine.
thank you
Old July 30th, 2009, 12:29 AM   #198
Vegas 9a and Neo4K
Have installed a Vegas 9a (32 bit) and trial of Neo4K build216.
In option render to AVI i can not see Cineform Neo4K codec (VFW ?).
Serge Victorovich is offline   Reply With Quote
Old July 30th, 2009, 12:55 PM   #199
CTO, CineForm Inc.
It is there, but it is called "CineForm HD Codec v5.x.x". With Neo 4K the control panel get you access to more quality, 4:4:4 and alpha channel support.
Old September 21st, 2009, 11:25 AM   #200
64 bit/cineform
Good Morning,
sorry for the double post as I posted this on the Vegas forum to but no answers prevail.
32 bit vegas 9b now will run my cineform files.
however my 64 bit program only lays down an audio track, no video at all.
A shame to have an I7 with 64 bit and not be able to optimize it in Vegas!!
Or is it just my configuration?
DATS ALL FOLKS
Dale W. Guthormsen
Old September 21st, 2009, 11:43 AM   #201
CTO, CineForm Inc.
Just your config as we add 64-bit support for Vegas several months ago, please contact support.
Old December 30th, 2009, 06:56 PM   #202
Vegas Pro 9,
Hi All.
Do Vegas 9 finally support 10 bit io?
The Forgiveness A Film About Life
Jan Tervo is offline   Reply With Quote
Old December 30th, 2009, 07:09 PM   #203
CTO, CineForm Inc.
Pester Sony about that. :) Sony has the tools they need (SDK access), so we do hope it will happen in the near future.
Old March 5th, 2010, 07:43 AM   #204
Vegas PRO 8 crashing again!
Im running vegas pro 8.0 on windows 7 and when i render a 5 min. project using cineform codec it fails around 45 percent. I do have a trial version of BlueFX rack focus that is enabled in some of the media. Do you think thats the culprit till i buy the software? The trial isnt up until 3 days.
Can i get some suggestions that i can try in the vegas preferences settings that might help?
windows 7 64bit
vegas video pro 8.0 32bit
cineform hdv codec
pc is a core2 quad at 3.0
6 gigs of ddr2 ram
nvidia 8800 gts to dual monitors
EDIT: I got it working. i had in the project properties pixel format at 32-bit. I switched it to 8 bit and its rendered alot faster and stable.
Chris
Chris Wysocki is offline   Reply With Quote
Old March 5th, 2010, 11:30 AM   #205
Project settings question
My video footage was shot on a canon xh-a1 in 60i. Please let me know if my settings are ok or should i change something that will make the overall picture better. The ones with ? im not 100% sure if its the right setting. Thanks, Chris
Right now my project template is like this in the Project Properties:
Template: HDV 1080-60i (1440x1080 , 29.970fps)
Field Order: Upper Field First
Pixel Aspect Ratio: 1.3333
Frame Rate: 29.970 (NTSC)
Pixel Format: 8-bit
Full Res Render Quality: Best
Motion Blur Type: Gaussian ?
Deinterlacing Method: Interpolate Fields
Render to New Track Properties
Template: HDV 1080
Frame Rate: 29.970
Video Format: Cineform HD Codec V4.3.4
Interleave every .250 seconds ON ?
Create an Open DML AVi file ON
Cineform Settings
decode/encode 709hd ON
video format (Automatic) ?
Old June 14th, 2010, 10:38 AM   #206
Neoscene Applied to Existing Projects
I just took the leap and ordered Neoscene and was wondering if it's possible to improve Vegas Pro 8 projects I've already completed by converting my project media (HDV video) via Neoscene into .avi files and then reload the project and when Vegas says it can't find the file names (due to the extension change), just direct it to the new filenames.
Also, does the manual/help menu in Neoscene go into much detail?
Thanks.
Mark
Mark Watson is offline   Reply
