Digital Juice, compression, alpha channel at DVinfo.net
CineForm Software Showcase
Old September 1st, 2007, 02:12 AM   #1
I'm working on an SD DVD project in Premiere CS3 and have added some Digital Juice backgrounds, lower thirds, and swipes. Some of these elements include an alpha channel. The DJ documentation recommends using QuickTime Animation with Alpha for rendering these elements. This results in about 1 GB per minute in file size. A similar avi or wmv file (without alpha channel) is a small fraction of that size. I have plenty of disk space so this is not a serious problem, but it just seems like a waste of disk space and bandwidth for these elements with alpha channel.
I happen to own Aspect HD so I thought I would ask, does it make sense to try the Cineform codec. I suppose I could just try it and see what happens, but I wanted to make an educated guess first. Any suggestions or comments? I posted this question on the DJ forum yesterday, but so far no suggestions for improvements over QT Animation.
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old September 1st, 2007, 09:41 AM   #2
CTO, CineForm Inc.
We definitely improved things a lot over the animation codec, we can do alpha 4:4:4:4 RGB encoding with significantly compression than the animation codec. However, we only offer 4:4:4:4 encoding in NEO 2K and Prospect 2K. To can try either of those products to see how much smaller and more handy your Digital Juice become.
Old September 1st, 2007, 09:52 AM   #3
CTO, CineForm Inc.
Could you please point me to the DJ forum thread so I can add a reply?
Old September 1st, 2007, 11:52 PM   #4
See http://www.digitaljuice.com/communit...tm.asp?m=75518
Best,
Christopher
Old September 6th, 2007, 10:30 AM   #5
Two quick questions:
1. Is 4:4:4:4 the only Cineform encoding that supports an alpha channel?
2. Digital Juice can render the video separate from the alpha. Could I use the Aspect HD CFHD to render both clips and put both clips on the Premiere timeline as though it was one clip of video + alpha?
Best,
Christopher
Old September 6th, 2007, 10:33 AM   #6
CTO, CineForm Inc.
1. Yes.
2. I never tried that, tell me how to do it.
Old September 6th, 2007, 10:51 AM   #7
In Juicer 3, select an asset that has an alpha channel (e.g. full screen wipe, lower third, etc). In the Output settings, there is an option "Render Alpha Separately". This will render two clips. One clip is the video and the other is B&W of the alpha channel.
I think these two clips can be put on the Premiere timeline and made to behave like a video with alpha. Perhaps someone can help with this step.
I'm certain it can be done in AE; just curious if it can be done in Premiere with results comparable to QT Animantion with Alpha, but with considerably less storage.
Best,
Christopher
Old September 6th, 2007, 11:00 AM   #8
The Alpha channel is exported monochrome, I believe, and can be used as a Track Matte for the other footage.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old September 6th, 2007, 11:06 AM   #9
CTO, CineForm Inc.
These two files will give you an effective 4:2:2:4 color sampling, while not 4:4:4:4, it is still pretty good. Someone please try both methods are post on their experience.
Old September 6th, 2007, 11:17 AM   #10
Yes, do you know the specific details of doing this in Premiere? For example, do you use an effect? I read through the Premiere documentation and did not see anything that addressed this specific issue.
FOUND IT! Video Effect->Keying->Track Matte Key->Matte Luma.
Best,
Christopher
