HD Link / Intensity Question at DVinfo.net
CineForm Software Showcase
Old August 24th, 2007, 07:38 PM   #1
On the Cineform web site, on the Intensity page, it lists the processor requirements.
I'm currently using Dual Opteron 3.0 GHz 856 CPUs and both processors are pegged at 100%. According to your site, I should be seeing no more than 80% usage.
Is this normal? Am I going to be dropping frames?
I'm not down converting.
Capturing using Aspect HD 4.3.1 Build 76 HD Link.
Also, is Cineframe 25 only available in Prospect HD with Intensity?
I switched my camera over to 50i and set up Cineframe 25, and I only get the 'No Video Input' message when I capture. However, using Black Magic's Media Express, I see video.
Jim
James Huenergardt is offline   Reply With Quote
Old August 25th, 2007, 09:48 AM   #2
CTO, CineForm Inc.
Are your opterons setup with their own memory. The Opteron design only goes fast when the CPU can acesss local memory. I would have thought 856/256s would be fast enough, but running at 100% is risking. As you are downconverting as Aspect HD will convert 1920 to 1440. You might want to try Prospect HD.
As for the 50i issue, that might be a bug, please file a trouble ticket so support can test that out.
Old August 25th, 2007, 09:18 PM   #3
Yes, they each have 2 GIGs.
Old August 26th, 2007, 08:31 AM   #4
I tried with a trial version of Prospect, and it pegged out at 100% as well.
Am I missing something, or are the 856 CPU's supposed be be faster than 252 CPU's?
On the Cineform web site, a 252 CPU should only be pulling 80%, so would have expected the same from my machine.
Any ideas?
Old August 26th, 2007, 08:39 AM   #5
CTO, CineForm Inc.
252s are slower than 856s, at least in clock speed, we only have 252s and 280s to do our testing on. I haven't heard that the extra hypertransport connection of the 8xx series is slowing them down, but something is definitely running too slow on our PC. Run SiSoftware Sandra and do a memory performance test, on Opterons you should get over 6GBytes/s (I seen 9-10GB/s on some systems.)
Old August 26th, 2007, 10:44 AM   #6
Well, it says 4298MB on the bandwidth test. Something must be up?
