Exporting CFHD from AE CS3 at DVinfo.net
CineForm Software Showcase
Old August 7th, 2007, 02:46 PM   #1
Hi David. Maybe this question has a simple solution and I've just not finding it here, but...
We have been unable to export from AE CS3 using the CFHD (Prospect) codec. It just doesn't offer that as an option as an AVI.
When we tried exporting as a MOV, using CF, it gives an error message saying the "Quicktime codec -8961 is missing".
What are WE missing? (oh, and we did load the CF selection before AE)
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old August 8th, 2007, 01:29 PM   #2
CTO, CineForm Inc.
reinstall Prospect HD, it needs to add components to AE CS3.
Old August 8th, 2007, 02:32 PM   #3
Sponsor: CineForm
This will happen if you're using 8 bits per channel and have only RGB selected in the Video Output Channels drop-down menu (in the Output Module Settings).
Change the color settings to 32 bpc and then in the Output Module, select RGB + Alpha and use Trillions of Colors+ for the Depth.
Then try rendering again and it should work.
Jake Segraves is offline   Reply With Quote
Old August 8th, 2007, 03:06 PM   #4
CTO, CineForm Inc.
Jake missed my reply. He is talking about the Quicktime error. 16-bit modes also work. We just never do anything in 8-bit, so it support for QT exports got missed.
Old August 9th, 2007, 10:36 AM   #5
Worked fine, thanks Jake!
