35 mm adapter probelms... at DVinfo.net
Old July 11th, 2007, 05:37 PM   #1
I am currently building a 35 mm adapter for my XL1 and I have no idea how to attach it to my camera. I see by the pics on Watchdog that there is a lens attached, but the instructions I have are only for the Panasonic DVX.
Pics seen here:
http://dvinfo.net/canon/images/images15.php
Anthony Montoya is offline   Reply With Quote
Old July 12th, 2007, 06:51 AM   #2
Some possibilities to consider depending on your optical path
1. Step-down rings, provided you can support the weight and not over stress the XL1 lens threads.
3. Cannibalize Bayonet mount adapter from a lens accessory
3. Buy one of the adapters or a used lens that mounts on the XL1 (e.g., the 1.6x or EOS adapter) and cannibalize the mount.
4. Machine a mount from a block of metal.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
