Newbie needs advice!
I am a Wildlife Photographer and have recently begun Videography in and during my hunting excursions, doing interviews, kill shots, approaches and so on. My question being about audio equipment and the required settings for my Canon XL1S. What are the recommendations for equipment for my type of surroundings? I will be mainly using the camera 20 to 30 feet in the air filming my hunting partner, in a hunting blind, at the truck or house, at the beginning of the hunt, after a kill, or in a boat a duck blind and so on... I want to know if the Mic on my XL1s will be sufficient to film interviews between hunters, plus do you recommend some sort of wireless mics? And now on to the camera settings; what is the difference between 16 bit and 12 bit and which should my camera be set to? I am using Adobe Premiere Pro 1.5 (not that I have a clue what I am doing) so is there any special settings I have to set to get the correct audio from my camera to the program? Any help would be greatly appreciated as this is very confusing stuff... Also, what would be a good learning toll for me to better understand Audio in my camera? Thanks,
Jeff Mayne Gone Thinkin Outdoors |
If you intend to shoot a lot in the field, a wireless mic system, including both handheld and lav mic capability will minimize issues with cables and serve for both interviews and "action" shots.
Which one? then what is your budget?
dpalomaki@dspalomaki.com |
#3 | |
Good Luck!
Waldemar |
Waldemar, WOW!!! Thanks for the response! My only question being is if I use 16 bit will I be able to add music tracks, sound effects and voice overs when I import into my Adobe, or do I need to utilize 12bit? I will only be utilizing the stock mic and a wireless mic! Oh another question for ya... I went out today with a brand new camera, I had recorded about fifteen minutes on a tape, (Panasonic Professional tape) then played it back on another vid camm then recorded again where I left off, played back again, then rewound the whole tape and recorded over it all. When I played back about fifteen to twenty minutes into the recording I had pixelated lines going across the middle of my screen which lasted for about five to ten seconds then quit, played a couple of minutes more, and did it one more time, then did not do it again throught the rest of the tape. Is it my hads already, or is it that the camera I am playing back on is doing it to the tape? PLEASE HELP!!! This is why I sold my last camera, becasue could not get through a sixty minute tape without having pixelation!@#^@$%@!$
#5 | |
Waldemar |
