The better XLR adapter at DVinfo.net
Old April 29th, 2003, 08:40 AM   #1
I only ever hear about the beachtek XLR adapters, or the MA-x00 adapters. Which of the two provides the cleanest sound? I can snag a brand new MA-200 for $275.
Andrew | Canon XL1s, ME66, Vinten Vision 3, GlideCam V16 (for sale!)
Andrew Petrie is offline   Reply With Quote
Old April 29th, 2003, 05:07 PM   #2
The Beachtek is passive, as is the Studio One and Signvideo. They should not introduce any noise (except perhaps for that coupled in from stray magnetic fields), but will have some insertion loss.
The MA-100/200 provides about 6 dB of gain, and because it is not passive it may add a wee bit of noise, but that is insignificant. It cannot accept line level signals.
Old May 4th, 2003, 04:19 PM   #3
in other words the MA-x00 can't accept line outs from say, a concert mixer feed?
Old May 5th, 2003, 03:41 AM   #4
The MA-x00 starts to clip at about -7 dBV input level, and normal line level from a serious mixer is +4 dB. Many mixers have an option for mic level output which is typically -35 dBV give or take. This is OK. Altenatively you can obtain an in-line attenuator. Shure and others make them.
And if the run is short and the electrical noise environment modest, you could forego the MA-x00 and run a unbalanced line from the mixer's tape output jacks (if it has them) setting the XL1 to line input.
Old May 5th, 2003, 05:32 PM   #5
Warden
Andrew, what I use is the Sound Devices MM-1. It gives me phantom power, decent headphone monitoring (with volume control), very high quality pre-amp, and line level out. The line out (about 6 inches) goes directly into the RCA line in. At times I use an attenuator cable, that Don speaks of. This allows me to go into the XLR connections on my MA-200 should I need 4 channel audio. The cable is available from sound Devices and Shure and others.
Jeff Donald
Carpe Diem
Jeff Donald is offline   Reply
