Uhf Vhf at DVinfo.net
Old March 17th, 2003, 09:41 AM   #1
Uhf Vhf
I dug out my old Azden wireless mic that I bought back in the late 80's! It is bad. The interference is really bad. It didn't cost that much so I'm sure it's VHF. A couple of questions.
1. Are the new ones better? Do they do a better job of getting the interference out?
2. Does the UHF models have interfernce problems too?
3. Since I'm on a tight budget right now, is there a cheaper wireless in UHF?
Bob Zimmerman is offline   Reply With Quote
Old March 17th, 2003, 12:05 PM   #2
The cheapest solutions are VHF. It is possible to find some that might work in your area, but since you are already having problems I think this solution is unwise.
UHF can have interference problems too, however, it is much less of a problem.
I always recommend the Sennheiser EW112P which sells for around $450. I think it is one of the best mics for the money.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old March 28th, 2003, 09:12 AM   #3
Boss Hog
Bob,
You might also look at using frequency agile wireless mics. These multichannel systems allow you to select from a number of frequencies to obtain the best performance.
UHF is currently popular because there are more channel choices available. I use Audio-Technica U100x series UHF without problems. To get the best performance from your wireless:
With UHF, line of sight between the transmitter and reciever is more important then with VHF.
A diversity system (two antennas/tuners/frontends per receiver) is less likely to suffer dropouts.
Make sure your talent does not wrap the antenna around the bodypack transmitter and shove it into a pocket. This can decrease the range on a wireless.
Alwasy use high quality alkaline batteries and fresh batteries for a critical shoot.
Find out more tips on the Audio-Technica website www.audio-technica.com (Using wireless)
Hope this helps
"Film is Art; Theatre is Life; Television is Furniture!"
Steve Savanyu is offline   Reply With Quote
Old March 28th, 2003, 05:24 PM   #4
The better VHF mcis use frequencies around 160-170 mHz give or take. The cheap units were around 49 mHz, and some around 29 mHz. THe lower frequencies are very interference prone.
Don Palomaki is offline   Reply
