Mics to capture dialogue? - Page 2 at DVinfo.net
Old March 19th, 2003, 07:41 AM   #16
I will be using the MA-200 i guess.
So will it only capture sound in 1 channel?
And if so, how do I copy the other sound to the other channel in post? Under which option do I go?
I normally use the timeline to add in soundtrack, sound etc, but I can't seem to find any option to adjust the right or left channel. Need help.
Michael Chen is offline   Reply With Quote
Old March 19th, 2003, 11:20 AM   #17
Capt. Quirk
My experience with onboard mics is this- It won't pick up any dialogue that is 10 ft in front of the cam. It will pick up the sounds of a camera snapping a pic 18 ft away. My voice ALWAYS come across loud and clear, no matter how quiet I am, even 10 feet behind the cam.
Murphy's Law strikes again... and again... and again...
K. Forman is offline   Reply With Quote
Old March 19th, 2003, 04:47 PM   #18
Hi Michael,
yep, all you got to do is to copy and paste the track of sound to the other track, eg. for FCP, A3 to A4. you can also link them as a stereo pair (in one of the menu options).
Adrian Seah is offline   Reply With Quote
Old March 19th, 2003, 06:46 PM   #19
I see. Thanks again for the answer.
I will try it once my next short film is completed. If i encounter any problem again, I will ask more questions. Thanks for helping!
Old April 15th, 2003, 03:28 PM   #20
re: dialog microphone
for high end "voice over" dialog, I was using a Rode NT1000...not a bad mic....now I have an AKG 1000C, which is a sort of stick condenser....can be used for standup, as a camera mic, or a short boom, but is round enuf to use as a VO mic...very punchy, full sound, with a presence booster to help cut thru the mix...nice for only $200....for a real vo mic, try an AT4047..that mic kicks butt, runs about $500 with a shock mount....sounded better than the Rodes or AKGs, way better than any smalll condenser. Needs phantom power, so its more of a studio mic......
Omens carry only as much weight as we choose to assign them.
Steve Leone is offline   Reply With Quote
Old April 23rd, 2003, 01:46 AM   #21
I have decided to rent it instead. I could rent it from a friend with an affordable price.
Thanks for all the advice given!
