Has anyone tried using the supplied cannon mic with extention cables (1/8 stereo and at DVinfo.net
Old January 19th, 2002, 02:00 PM   #1
Has anyone tried using the supplied cannon mic with extention cables (1/8 stereo and power) into Audio1 for a BOOM mic?
Thornburg Cinema is brought to you buy vOCesUGa . . . makers of 35-70 mm projectors.
email reply too
thornburgav@hotmail.com
blake edwards is offline   Reply With Quote
Old January 19th, 2002, 08:24 PM   #2
Be aware that it is an unbalanced system, so long leads can pickup noise. Also you have to provide both the mic and power leads.
It can be done. I've done it with the L2, but had no reason to do so with the XL1.
Old January 19th, 2002, 08:47 PM   #3
thanks for reply
im having trouble getting my audio 2 to the computer via the xl1
email reply too
Old January 20th, 2002, 09:08 AM   #4
If the question is about trying to transfer AUDIO 2 (12-bit, 4 channel mode) sound to a PC via firewire, be aware that your capture card's DRIVERS must support 4-channel capture. Many do not, in which case you may have to capture AUDIO 2 in a second pass, possibly using your audio card.
Old January 20th, 2002, 11:24 AM   #5
thanks for the post
i would be happy just getting the audio 2 captured. this isnt happening. i have tried all the suggestions on here and read the manual for the xl1
it will not capture the second audio in vegas video
i have the ati dv wonder card BTW
email reply too
Old January 20th, 2002, 01:44 PM   #6
My informants tell me that Vegas Video 3 does NOT support capture of 4-track audio from a camcorder/DV player via firewire. (Have you checked the VV3 manual, I did not see it mentioned in the on-line manual?) And that is not the XL1's fault - blame the VV3 developers.
You may have to capture the AUDIO 2 tracks via analog playback from the XL1's AUDIO 2 output jacks.
Don Palomaki is offline   Reply
