Filter sizes adaptable? at DVinfo.net
Old February 4th, 2003, 09:04 PM   #1
Probably a dumb question, but here goes:
I just acquired a nice Tiffen filter set for my GL1
(58mm) / is it possible, by way of a step-down ring,
to use these on my XL1 as well? - or is the 58-72mm
too great of a size drop?
Scott Moore is offline   Reply With Quote
Old February 4th, 2003, 09:55 PM   #2
Warden
You might get away with it if you shot in telephoto, stop your lens way down (F/16 or more). But that is too limited to be practical. You can go the other way though, 58mm to 72mm via a step-up ring. that will work with everything except extreme wide angle.
Jeff Donald
Carpe Diem
Old February 4th, 2003, 11:11 PM   #3
I guess I'm still a little dense on this -
are you saying use a step UP ring rather than a
step DOWN ring?
and the operation would be:
XL1>step up ring>58mm filter?
OR am I missing your point completely?
Old February 5th, 2003, 01:24 AM   #4
Jeff means you can use a 72mm filter on your GL1 via a 58mm to 72mm step up ring. To use your 58mm filter on the 72mm threaded XL1, you'd need a 72mm to 58mm step down ring.
If it was me, I wouldn't bother using the 58mm filter on the XL1, unless like Jeff says, you plan on shooting only telephoto stuff.
Dylan Couper is offline   Reply
