XL1s Problem relating to tapes... at DVinfo.net
Old March 4th, 2006, 08:55 AM   #1
Hello all,
I was about to upload a video from a weekend of shooting when I encountered a fairly serious problem in my mind. I put the first tape in to rewind for upload, and while rewinding the tape was unwound, twisted, tore, etc etc. I got the remove tape warning. I thought it may had been a problem with the tape so I put a blank one in and it had the same problem. I'm not familiar at all with problems like this, so I was wondering if anyone else has had this problem, and/or if anyone has any suggestions as to what I should do next.
Thanks in advance all!
Jack Miles is offline   Reply With Quote
Old March 5th, 2006, 03:13 AM   #2
Oh,man ,breaking tapes?I would let an expert check it out.Send it in for a check out.
Jack Smith is offline   Reply With Quote
Old March 5th, 2006, 10:00 AM   #3
Hi Jack...sounds pretty familiar to me! My XL1s started doing the exact same thing a couple of months ago (only a month out of its warranty and hardly used), when rewinding a tape the message 'Remove the Cassette' would appear. This would happen say 1 in 5 times when rewinding, and at least half the times, when removing the cassette it would have been chewed up. Not good! I did a search on the net and found that its seems to be quite a common occurance with Canon tape transport and not just relative to the XL models.
I took the camera into my nearest Canon agent and they very quickly diagnosed a faulty part...idle gears. They replaced the part and I had the camera back within 48 hours. It cost about £80 (Be about $140 I suppose).
Everything has been fine since, my advice would be get it looked at, certainly if its happened more than a couple of times.
Carl Barlow is offline   Reply With Quote
Old March 5th, 2006, 06:49 PM   #4
Very helpful, thank you.
$140, yikes, I had better things to spend my money on. Oh well. I'll probably send it back to Canon to have it fixed and make sure all is well. Thanks again.
EDIT: Where exactly did you take/send your camera to get it back so fast?
Old March 5th, 2006, 06:54 PM   #5
See http://www.dvinfo.net/canon/skinny.php#service for Canon Service contact info.
Old March 6th, 2006, 11:04 AM   #6
I know...tons of better ways to spend 140 bucks eh? I'm in the UK and luckily only 10 miles from a service agent. As I had a wedding to film within 5 days of the fault they really helped me out and turned it around in 2 days.
They did actually say that they keep a good stock of that particular part as it was a 'popular' fault....Hope you get it sorted.
