fields not in sync? at DVinfo.net
Old January 19th, 2003, 04:16 AM   #1
fields not in sync?
Could someone please have a look at this image :
http://mysite.mweb.co.za/residents/net03472/index.html
It is a jpeg picture the full bitmap image is also availible at 1.2Meg, captured it off a video file using premiere.
It seems to occure only when the camera (Canon xl1s PAL) pans. I believe it is caused in the camera, but maybe it could be related to my pc.
Could anybody tell me the probabile cause.
Thank you
Llewellyn
Llewellyn Thomas is offline   Reply With Quote
Old January 19th, 2003, 07:17 AM   #2
You are seeing a frame capture (two fields separated in time by 1/50/sec in PAL, 1/60 in NTSC) thus the comb effect at contrasty edges. This is cause by the camera motion in the pan, each field is seeing a slightly different image. To avoid this with the XL1, shoot in frame mode, or just capture a field.
Note that you will see a similar sffect without pan if you have a fast moving object in the image.
Old January 19th, 2003, 07:28 AM   #3
Warden
This topic has been discussed before and with a good explanation here The original poster's link is broken but you'll see it is common for stills in NTSC or PAL.
Jeff
Old January 20th, 2003, 05:08 PM   #4
RED Code Chef
I've also posted a lengthy reply on your other thread:
http://www.dvinfo.net/conf/showthrea...&threadid=6168
Rob Lohman, visuar@iname.com
Old January 21st, 2003, 01:02 AM   #5
Thank you all very much.
Llewellyn
