#31 |
Sorry, not possible with either camera.
Please search for earlier discussions of this topic. |
#32 |
How do you check hours on head?
Hello,
I just got a hold of an XL1S and I want to see how many hours are on the heads. This camera has had two owners before me. It's in great conditon I just want see how much use I will have with it. So if there is a way to check the hours on the heads I'd love to know. Thanks Ken Stevenson |
#33 |
There is no function available to the owner of an Xl1 ot XL1s to determine the number of hours of use.
I believe that that Canon Service can retrieve this information, but I have no personal knowledge.
Dan Keaton Augusta Georgia |
#34 |
I thought as much, thanks for the response. I had planned on sending it in anyway to be checked.
Thanks again Ken |
#36 |
There is no documented (in the service manual) way to read head hours on the XL1, and I suspect on the XL1s.
Head hours would include time spent in record pause, play pause, playback and record mode with tape in the camcorder. Running a cleaning tape adds hours as well, but I do not know at what rate. In any case, given the differences among tapes, a better indication of head condition might be the output levels read from a standard test tape.
dpalomaki@dspalomaki.com |
#37 |
I believe you're right, but I can say with certainty that they will not share this information with a customer.
#38 |
How to you check camera for hours
I have an XL-1 is there a way to check the camera for hour use. If so please explain
#39 |
I believe the answer is "no". The DVinfo search function can often answer questions like this for you:
http://www.dvinfo.net/conf/showpost....39&postcount=2 http://www.dvinfo.net/conf/showthread.php?t=59957 http://www.dvinfo.net/conf/showthread.php?t=29078 http://www.dvinfo.net/conf/showthread.php?t=85744 |
#40 |
count your tapes ... that's as best as i could come up with
#41 |
Have merged several separate discussions into one big 'ol thread about checking hours on these cameras.
#42 |
Check Hours of use on Canon XL1
Is there anyway to check the hours of use on the Canon XL1?
