urgent response at DVinfo.net
Old February 2nd, 2006, 07:13 PM   #1
urgent response
what is the difference between the CA-910 and the CA-920...I want to order this for the XL1S but I don't know which to get. I'll be using the coupler with it..HELP !!
Dean Orewiler is offline   Reply With Quote
Old February 2nd, 2006, 07:20 PM   #2
The 920 is just a newer version of the 910. No real difference. Both are compatible with the entire XL / GL line.
Old February 3rd, 2006, 10:23 PM   #3
thanks for the info Chris
Old February 3rd, 2006, 10:53 PM   #4
Images: 1
They are except if you use the 910 on the XL2, it will show you have a half charged battery attached. There is an additional contact that was added on the XL2 that senses the AC adapter attached and changes the vf display accordingly. But with that said, I did run my then brand new XL-2 for 3 hours on the old adapter and the 'battery' never went below half charge.
-gb-
Old February 3rd, 2006, 10:57 PM   #5
Dang how about that. I had no idea. Thanks for the info Greg,
Chris Hurd is offline   Reply
