Does anyone have a 'Microphones 101' article for the XL1s? at DVinfo.net
Old January 6th, 2003, 01:23 PM   #1
I'm rather ignorant about mics and am looking for a single spot that tells what's available and what each thing does. Ya know just a basic chart maybe that says mic type and usage and what works best with my camera for given situations. I'm considerng getting a MA-100 or MA-200 ( not sure I understand the differences there ) because I know I want to be able to use at least 2 external mics and I like the shoulder rest feature. Sorry this is so vague and naive, but I really don't know much about this yet and am trying to learn.
Mark
Mark Argerake is offline   Reply With Quote
Old January 6th, 2003, 04:15 PM   #2
Warden
Hi Mark,
Many of your answers can be found by using the search function in the upper right corner. The basic difference between the MA-100 and MA-200 is the number of audio connectors. The Skinny http://www.dvinfo.net/canon/xl1s-skinny.php#ma200on the DV Info is a good start. Canon's site has good info also http://www.canondv.com/xl1s/a_audio_access.html If you have additional questions post back and I'll try to answer them.
Jeff
Old January 6th, 2003, 06:12 PM   #3
The Shure.com web site has some good information on mics and using them.
Old January 6th, 2003, 09:09 PM   #4
How to compare microphones etc..
Here's a site that has pretty good "Mic 101" information, lists, comparison charts, and specs on quite a few different ones. You may find that it's geared for pro audio but it should get you started anyway.
http://www.microphonereview.com/sect...p?ID_Section=1
Hope it helps,
Mark
I'm humbled by the greatness that surrounds me.
Mark Austin is offline   Reply With Quote
Old January 6th, 2003, 09:19 PM   #5
Also, Jay Rose (he does the Audio column for DV Magazine) has some good information on his site: www.dplay.com
He also answers questions quickly on the dv.com audio forum.
-- Vic Owen --
Vic Owen is offline   Reply With Quote
Old January 7th, 2003, 08:37 AM   #6
Hey you guys rock. Thanks for the info. Now I've got plenty of readin' to do.
