Frame Mode Output Question at DVinfo.net
Old September 9th, 2005, 07:30 PM   #1
If I shoot footage in 'frame mode' on my XL1s, in post should I then choose progressive as an output option in my NLE or leave it interlaced?
www.facebook.com/projectspecto
Marco Wagner is offline   Reply With Quote
Old September 10th, 2005, 06:25 AM   #2
I tried both, and progressive looked better on the computer screen, because with interlaced it looked like I had almost invisable (but still visable) horizontal lines (but not like the usual interlacing lines) and when I export in progressive, I didn't had these. But it could be that on a television screen they both look the same.
I do have to mention I have a PAL XL1s, so mine was 25p, and not 30p.
I would say: try to export a minute in both ways, and look if you see a difference, and if so, what you like the best.
Best regards,
Mathieu Ghekiere is offline   Reply With Quote
Old September 13th, 2005, 03:11 AM   #3
RED Code Chef
Your complete workflow should remain progressive for optimal look:
- project settings
- footage settings
- export settings
Good luck!
Rob Lohman, visuar@iname.com
Old September 13th, 2005, 04:33 AM   #4
But Rob, to capture, you have to put your NLE in interlaced, though? Because it isn't really progressive?
Old September 13th, 2005, 01:11 PM   #5
What NLE are you using? For Adobe Premiere, if you export your clip as "interlaced," it'll just spit out the video whereas "progressive" will try to deinterlace your clip. Since your video was recorded in frame mode and no deinterlacing is necessary, I suggest leaving it in "interlaced."
Kin Kwan is offline   Reply With Quote
Old September 13th, 2005, 07:32 PM   #6
Premiere Pro 1.5
4:3
final output for DVD
Rob says progressive
Kin says interlaced
That's one vote for each, lol. I guess I'll be trying a bi-directional test then. I was hoping someone had already had this issue.
Old September 15th, 2005, 01:34 PM   #7
RED Code Chef
It should be progressive. You can't do a progressive or interlaced capture with
DV. DV is always captured as is. Progressive footage is not interlaced. It is just
stored as an interlaced signal in DV (which is something different). Keep
everything progressive if you want progressive. Simple as that.
Old September 15th, 2005, 03:46 PM   #8
Marco, which export option are you using in Premiere Pro 1.5? When I go to File > Export Movie > Settings > Keyframe and Rendering, I only see the options "No fields (Progressive Scan), Upper Field First, and Lower Field First" and nothing about Interlaced. There's a "Deinterlace" check box, but if your footage is progressive, you shouldn't have to mess with that.
My DV3000U has a pseudo progressive mode and I've always left the options at 'No fields (Progressive Scan)' and the 'Deinterlace' box unchecked when I export.
Old September 15th, 2005, 07:00 PM   #9
I think the default option is Upper Field first. I have always left it at that.
Old September 15th, 2005, 09:45 PM   #10
I just did a quick test by exporting one of my progressive clips with the 'Upper Field First' setting and the 'No Fields (Progressive Scan)' setting. It seems like 'No Fields (Progressive Scan)' is what you need. Run a test for yourself and you'll see what I mean.
Old September 16th, 2005, 05:45 PM   #11
Hey great, I'll give that a try tonight. Thanks a bunch!
Old September 29th, 2005, 12:28 PM   #12
Interlaced NTSC DV is always lower field first. Lower field first.
Lower field first.
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old September 29th, 2005, 02:04 PM   #13
Hugh, according to Marco, he's working on progressive footages which means there aren't any fields.
Old September 30th, 2005, 08:00 AM   #14
A ha! Of course. Then, when in progresive, the option of lower or upper should be shaded?
Old September 30th, 2005, 08:33 AM   #15
Nah, it's not shaded. Like I said in my 2nd to last post, you have to set it to "No Fields (Progressive Scan)."
