animation with dv at DVinfo.net
Old September 13th, 2001, 08:52 AM   #1
Guest
Posts: n/a
animation with dv
I was thinking that if I used the still photo mode on the camera, I may be able to do some animation. Is this possible? Can I capture a still image from the camera and put it as a single frame on my timeline, because if so you could do some pretty cool animation or even time-lapse. Am I mistaken or not?
Old September 14th, 2001, 03:27 AM   #2
That should work, I think. You can normally use any (still) images (.BMP .JPG) in the timeline (Premiere).
Film & TV locations & production Spain
http://www.fotofilmvideo.com/
Dan Uneken is offline   Reply With Quote
Old February 9th, 2003, 05:01 PM   #3
I have recently done a shot that could be called animation on the XL1s. The shot is of a fuel filler cap on a car screwing in, apparently by itself. The way I did this was very simple, I composed the shot, hit record and then did up the filler cap about an 1/8th turn, moved my hand out of shot for a second, moved the cap another 1/8th turn until it was ready. To turn it into the final shot I simply selected the frames I wanted, i.e when my hand wasnt in shot, and dropped them into the timeline. It actualy seemed way too fast at first so I took two frames for each still and then made the sequence into a nest (Final Cut Pro - I think premiere has a similar function although I forget what they call it - it has been ages since I've used it!) I then made the nest slow motion and enabled frame blending, this gave a kind of half frame inbetween my frames that made it look more like it was real motion. The final shot works well.
Onto time lapse - the way I do this is to hook up my iBook to the XL1s with firewire and using software called BTVPro (http://www.bensoftware.com/) I specify a number of frames to be captured per minute and set it going. Premiere has its own built in interval frame capture mode so there is no need for third party software. The other, easy, way of doing time lapse is to simply roll the tap for the length of time you want to record and then capture it all and speed it up in your editing software, you have more control over the speed with this method but are limited to the duration of the tape.
Hope this helps!
Ben Vallack
Filmmaking - Web Design
Ben Vallack is offline   Reply With Quote
Old February 11th, 2003, 04:20 AM   #4
RED Code Chef
There is some more information on this subject in the following
threads:
http://www.dvinfo.net/conf/showthrea...&threadid=2399
http://www.dvinfo.net/conf/showthrea...&threadid=1007
http://www.dvinfo.net/conf/showthrea...&threadid=1441
http://www.dvinfo.net/conf/showthrea...&threadid=6104
Rob Lohman, visuar@iname.com
Old February 11th, 2003, 04:52 AM   #5
Wouldn't using a more hi-rez still digital camera be a better idea, you even sorta do it in hd rez if you wanted to.
Zac
Zac Stein is offline   Reply
