Matte boxes - know zip - Page 2 at DVinfo.net
Old October 24th, 2002, 04:22 AM   #16
I'd also be interested in seeing how you've set up an XL-1 with the anamorphic adapter. Any chance of seeing some images of the rods and mounts?
Thanks for the heads up.
Bar3nd
www.raamw3rk.net
digital storytelling and vfx
Barend Onneweer is offline   Reply With Quote
Old October 24th, 2002, 01:11 PM   #17
When I get some free time I'll document my setup. I'll put some images of the rig on my website.
Adrian
Adrian van der Park is offline   Reply With Quote
Old October 24th, 2002, 04:19 PM   #18
Moderator
Great.
No need to get too detailed, a simple description will suffice!
Thanks Adrian.
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old November 9th, 2002, 10:14 PM   #19
Retired DV Info Net Almunus
Donald,
This is way after the fact...but I just wanted to say thanks for all the info you've given here! Especially the still shot examples you've provided.
Have you heard anything else regarding Tiffen coming out with a cheaper model?
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old December 16th, 2002, 10:50 PM   #20
How about the 16X manual? Need lens hood!
Does anybody have any experisnce on where to get a decent lenshood and/or mattbox that will fit the 16X full manual Canon lens? Would the Tiffen or Lee work? Thanks!!
JD
Chaos, panic, & disorder.....my work here is done
John Dynes is offline   Reply With Quote
Old December 16th, 2002, 10:59 PM   #21
If you're referring to the XL1/XL1s lens, you must be referring to the 14x "full manual" lens since there is no 16x full manual. Correct?
Old December 17th, 2002, 01:02 AM   #22
Uhm, yes there is... at least I hope it does exist, because I just ordered one :-)
http://www.zgc.com/html/canon_16x_manual_servo_zoom_le.html
Bar3nd
Oh, and for matteboxes I'm looking into the Chrosziel 4x4 DV Mattebox, which fits the Canon lenses just fine with an adapter ring. But I think Cavision also makes a decent one.
I've heard about the Lee mattebox being used with the XL-1, so that will probably be fine too.
www.raamw3rk.net
Old December 17th, 2002, 02:11 AM   #23
That lens is what we refer to as the 16x manual, but it does have some auto functions available (auto iris), so might not be considered "full manual" by some, whereas the 14x lens has no automatic functions and may be more suited to the title of "full manual".
That is what Ken's statement is based on, so really everyone is right.
Old December 17th, 2002, 08:50 AM   #24
It is the 16X manual lens with auto iris. Howz that? :) I shouldn't type past midnight! I also should have mentioned that I am using a Century Optics .7 zoom thru wide eye. So thats what I need as far as geting a lens hood/matte box to fit on!
I will not type late at night I will not type late at night I will not type late at night I will not type late at night I will not type late at night I will not type late at night
Old December 21st, 2002, 01:24 PM   #25
The 16x is manual, but you have the option of using the motorized zoom from the controls on the camera or other device (LANC ,etc )
How does the CaVision rods connect to your tripod plate? I have a Bogen/Manfrotto and I wonder will the Cavision plate work with standard sized tripod plates?
John Threat is offline   Reply With Quote
Old December 22nd, 2002, 12:56 AM   #26
Slash Rules!
Rods don't connect to your tripod plate. They connect to a mounting plate that screws into the tripod plate screw hole. The mounting plate has its own screw hole, where you attach the tripod plate.
Josh Bass is offline   Reply
