differences in xl1 lens? at DVinfo.net
Old October 1st, 2002, 07:15 AM   #1
dvmonkey2
Posts: n/a
Does anyone know of a web site that shows the differences in the xl1 lenses?
Old October 1st, 2002, 09:38 AM   #2
Retired DV Info Net Almunus
What do you mean my "differences"? Photos of the lenses? Each of the lenses' specifications tell the basic story of their characteristics. Look at the XL1 Watchdog section of this site (dvinfo.net/xl1.htm) for more info.
Go to "Articles Menu" > "Guide to XL1 & XL1s lens options".
Old October 1st, 2002, 11:57 AM   #3
dvmonkey2
Posts: n/a
I remember seeing a website that showed the differences in lenses, how a 14x looked zoomed out all the way and how a 16x looked and whatnot.
One was a picture of a construction worker on a scaffold I believe
Old October 1st, 2002, 03:29 PM   #4
You mean pictures that represent a visual comparison of the maxium telephoto capabilities of the lenses, right?
The only one I remember of a worker on a scaffold was on Ebay.
Old October 1st, 2002, 09:32 PM   #5
Warden
The difference between the 16x and the 14x is insignificant. The 16x is 5.4 - 87mm (620mm in 35mm terms) and the 14x is 5.7 - 80mm (577mm in 35mm terms). The difference in magnification is less than 10% which is indistingusable by the human eye. Size and distance are very hard for the human eye to judge. A general guideline is size must increase by at least 33% for the eye to notice a change in size.
Jeff
Old October 2nd, 2002, 08:26 AM   #6
dvmonkey2
Posts: n/a
I think it was a picture difference of a wide angle lens and a zoom lens, possiby. I take it a wide angle lens has nothing to do with a 14x or 16x lens?
Im obviously getting confused here! HELP!
Old October 2nd, 2002, 09:32 AM   #7
Warden
Out and in are confusing terms when used to describe zoom positions. The 14x or 16x descripes the amount or range of zoom. For example the the 16x zooms from 5.4mm to 87mm (5.4 times 16 equals 87mm). The wide angle position are even more alike than the telephoto range (16x lens is 5.4mm or 38mm in 35mm film terms and 14x is 5.7mm or 41mm in 35mm film terms). The difference is much less than 10% and might not even show because of variable in the monitors viewed on.
Jeff
Old October 4th, 2002, 07:25 AM   #8
See also my Guide to XL1 Lens Options, in the articles section of the XL1 Watchdog at www.dvinfo.net/xl1.htm
There's practically no difference between the 16x auto, 16x manual and 14x manual at the wide end of the lens. There is a substantial difference with the 3x wide angle lens, however. Hope this helps,
Chris Hurd is offline   Reply
