frame mode and After Aftects at DVinfo.net
Old November 22nd, 2001, 12:19 PM   #1
Hi there,
When you shoot something in frame mode and you want to edit it in Adobe After Effects what do you choose with the "interpret footage" dialog. No fields cause it's frame mode or lower field first cause Dv is lower field...
Many thanx in advance,
Sen Haerens
Sen Haerens is offline   Reply With Quote
Old November 24th, 2001, 04:35 PM   #2
Import it as you would any normal interlaced footage.
Frame movie mode is not technically progressive scan. It's an interlaced frame of a still image, (pretty cool idea actually,) so I'd bring it in as lower field first.
Hope this helps.
Daniel G. Trout
Fishmonger Media Consulting
Daniel Trout is offline   Reply
