Depth of field in Video at DVinfo.net
Old September 19th, 2002, 04:40 PM   #1
Jeremy Evans
Posts: n/a
What is the main difference between the DOF in video vs film? Is it only the lens? If I was using a mini 35 with an appropriate lens, would that give the xl1s the flexibility of a good 35 film camera?
Jeremy
Old September 19th, 2002, 05:32 PM   #2
To answer the second part of your question, this is one of the major advantages of the mini35 adapter. It preserves the shallow DoF ability of those wonderful cinematic lenses.
Regarding the first part of your answer, we have a couple of Depth of Field discussions going on already. I'll try to post the direct links, but you could do a search on the term "depth of field" and probably pull up the ones I'm thinking about. Hope this helps,
Old November 22nd, 2002, 11:24 AM   #3
Chris,
You wrote in response to Jeremy:
"..To answer the second part of your question, this is one of the major advantages of the mini35 adapter. It preserves the shallow DoF ability of those wonderful cinematic lenses..."
IS this kind of adapter available for use on most digital video cameras, or just the XL1S??
Jean King
Jean King is offline   Reply With Quote
Old November 22nd, 2002, 05:51 PM   #4
I believe the mini-35 adapter is also available for pd-150. But don't think you'll get a film look from it. The only thing you'll get is the depth of field of 35mm film. And for such a high price I would go for a standard manual lens....
Bryan Johannes Onel is offline   Reply With Quote
Old November 22nd, 2002, 08:03 PM   #5
Warden
This thread http://www.dvinfo.net/conf/showthrea...&threadid=3926 should answer most questions on DOF.
Jeff
Jeff Donald is offline   Reply
