Canon Service - Page 9 at DVinfo.net
Old November 22nd, 2006, 02:19 PM   #121
All I meant my obviously not licensed is that since Cannon will only service the cameras themselves the local place is not licensed. I think they are a reputable place and I am hesitant to send everything off.
I was reading in the archives and some people recommended just recording for a half hour and then reviewing the tape to see if there was any fragmenting etc. Their thought was that if you did this and there was none you were good to go. Is that the general consensus? It is an xl1s and hasn't had much use, so would like not to spend the 252 dollars if it is avoidable. Thanks,
Andrew
Andrew Dryden is offline   Reply With Quote
Old November 23rd, 2006, 01:17 AM   #122
If you're willing to put up with that kind of aggravation, go right ahead. :) I take it you don't do any kind of event shooting or jobs where time is an issue.
Lorinda
Old January 20th, 2007, 11:22 PM   #123
Time to send in my XL1s to Canon
My camera has worked flawlessly for about the last year or so since I bought it used on EBay. Camera sat for a few days since last successful use and when my new 7" external LCD monitor arrived to work with my new jib I plugged it in and no zoom, no focus... removed the lens, cleaned with eraser and denatured alcohol on the contact, still no go... removed the batteries for several hours and tried again with no luck. Funny thing is that the camera zoom and focus works for about the first 15 seconds on powering up, but then nothing. When I hit the zoom in - zoom out toggle after that it shows the square and triangle on the zoom (in the display) like it knows I'm hitting the toggle switch, but doesn't go anywhere... No error message, and will playback fine. Hopefully nothing major, we'll see what happens. Anyone have any other bright ideas to try?
Canon XL1s, Canon Digital Rebel, Misc. lenses and other toys... : )
G. Scott Roberts is offline   Reply With Quote
Old January 21st, 2007, 12:52 AM   #124
Sorry, there is nothing else you can do except send the camera in to Canon service.
Old January 21st, 2007, 07:21 AM   #125
I recommend some last minute tests before sending it off to Canon.
I don't know what 7" monitor that you are using. So, disconnect it and run the test again.
If you have any other lenses, try them.
Have you tested with other batteries? Does the battery power show full power?
Dan Keaton
Augusta Georgia
Old January 21st, 2007, 08:07 AM   #126
Could be the lens fuse, not the camera. So yeah, check with a different lens. Or at the least, send body AND lens back.
Richard Alvarez is offline   Reply With Quote
Old January 22nd, 2007, 04:21 PM   #127
Yikes, dropped off my XL1s this morning to Canon in Irvine, CA (only about 40 miles from me), and was told it's a minimum of $400.00 for repair of an XL1s! I expected a few hundred after cleaning and resetting / fixing whatever, but $400 min? I hope it's back to brand new when I get it back. The $400.00 is supposed to include fixing and cleaning, so we'll see...
Old January 22nd, 2007, 06:19 PM   #128
I had the exact same thing happen to me but fortunately mine was still under warrenty. If they have the part its an easy fix but with me they had to order it and that took awhile.
Chris Colin Swanson is offline   Reply With Quote
Old February 15th, 2007, 03:49 PM   #129
Canon XL1 Repair Price
I sent a XL1 camera in for distorted playback image. The repair description for the camera itself is "playback image distorted when panning or if subject moves. Replace drum. Unit never serviced. Check all functions. Clean and adjust. lens seperated.
Parts are $131 and labor $400
Seems really excessive?
Charles Culpepper is offline   Reply With Quote
Old February 15th, 2007, 04:45 PM   #130
Seems about right to me for a drum replacement.
Old February 15th, 2007, 05:04 PM   #131
Contributor
That used to cost about $3,500 on my old Betacam camera and I had to do it about every 3 years.
Old February 15th, 2007, 05:06 PM   #132
I assume you tried a good run of a cleaning tape?
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old February 15th, 2007, 05:41 PM   #133
Realize that with a new drum, comes new heads. Considering the transport has also been 'cleaned and adjusted'... it's a pretty good deal and the old XL1 should serve you well.
Old February 15th, 2007, 11:30 PM   #134
$400 is their magic number, that's what I just paid for my XL1s that would not zoom/focus. That was the price for "Reseat all connectors, adjust focus, adjust exposure." on the lens, then "Clean Drum ass'y. Perform tape path adjustment. Test loading, eject, record, playback - Good". You got more than me for the same amount... If you haven't, I learned (through this site) you should register your XL1s through Canon's web site for the "XL Series Owners Club" https://www.usa.canon.com/consumer/c...8&modelid=7471 to get specials such as routing cleaning discounted prices (questionable at the Irvine, CA location)...
Old February 16th, 2007, 09:10 AM   #135
Mike
That's right. We cleaned with a cleaning tape thoroughly.
