what does a telextender do? at DVinfo.net
Old August 27th, 2002, 11:24 AM   #1
Woodyfang
multiply the amount by which you can zoom?
10 films online http://www.undeadarmy.org
STOP PRESS!! http://www.honeyweasel.com STOP PRESS!!
Lighting Cameraman / Director / Producer / Music Producer / DJ / Web Designer / Visualist / Media Student / IT Tutor / Digital Artist
W00dy See, W00dy d00...
Hagop Matossian is offline   Reply With Quote
Old August 27th, 2002, 03:19 PM   #2
Hi,
what ever the value of the extender is, is what you times the lens. i.e. the stock 16X 5.5mm-88mmIS XL-1 lens with a 1.6 extender is close to 1000m ( in35mm equivalence) If you were talking just plain 35mm lenses a 50mm lens with a 2 x extender wwould be 100mm.
Bruce
B. Moore is offline   Reply With Quote
Old August 27th, 2002, 04:24 PM   #3
Warden
Bruce is correct. The math works out like this: 5.5mm-88mm zoom multiplied by 1.6 gives us a 8.8mm-140.8mm zoom lens. The 35mm film equivalant can be obtained by multplying those result by 7.2 (63mm-1014mm). This yields a magnification of a little over 20x at maximum zoom (1014 divided by 50). But, like all things in photography and video, the gain comes at a price. You will loose a little over 1 stop of light. A 2x extender losses 2 stops of light.
Jeff
Old August 28th, 2002, 12:17 PM   #4
Woodyfang
cheers guys
Old August 28th, 2002, 07:49 PM   #5
Thank you Jeff,
you put it much more elloquently and informative thanI. I was not sure about the exact f/stop loss,but I thought he'd figure that part out.
Thanks again
