Data Code at DVinfo.net
Old August 14th, 2002, 02:45 PM   #1
Doug Bastron
Posts: n/a
Data Code
I've shot some footage and would like the Date and Time to appear on my final footage when captured. I'm using the XL1.
I've turned on the Data Code "On" by pressing the Wireless Controllers "Data Code" button. When I do this I see the Date and Time through the XL1 viewfinder. However, when I capture the footage the Date and Time do not appear. Is it possible to include the Date and Time in the final footage?
Also, I shot the footage yesterday, August 13th. But, when I turn on the Data Code and play the tape the date is August 14th, the day I'm playing the tape, not the day I shot it.
Doug
Old August 14th, 2002, 02:46 PM   #2
I would do it in post. You can really customize it in many different ways.
What do you use to edit?
Marc Betz
Marc Betz is offline   Reply With Quote
Old August 14th, 2002, 03:01 PM   #3
Doug Bastron
Posts: n/a
I'm using Premiere 6. I was hoping that the date and time the footage was shot could be displayed when played from VHS or a CDROM. Kinda like surveillance cameras do.
Doug
Old August 14th, 2002, 03:04 PM   #4
I don't know if premier has an option for date code. Perhaps someone else that uses it will post a message on how to do it. Vegas Video has it as an effects option. Highly customizable.
Good luck
Marc Betz
Old August 14th, 2002, 03:07 PM   #5
Warden
It's page 62 of the manual Menu>system>Char. Rec.>ON You will not be able to hide this at a later time. Pages 79 and 80 cover camera data. Camera Data can be displayed by pressing display button on the remote on and off. If your playing back from a different machine than the camera, the Camera Data usually does not playback.
Jeff
Old August 14th, 2002, 03:21 PM   #6
I still think doing it in post would be the best way to go because it is undo-able, just a personal preference.
Marc Betz
