XL1 / XL1S focus hunting backfocus problems - Page 18 at DVinfo.net
Old July 8th, 2005, 02:09 PM   #256
Lower corners out of focus.
I was shooting some footage with my XL1s at a hockey game through plexi glass and I noticed on play back the the lower left and right corners are out of focus.
The image was quiet distorted in those areas but the rest is fine.
Is this just a normal occurance because of the plexi? or do I have to set up my camera better? Any suggestions would be great!
Rob Ketting is offline   Reply With Quote
Old July 8th, 2005, 02:18 PM   #257
Got a grab you can post???
ash =o)
Ash Greyson is offline   Reply With Quote
Old August 16th, 2006, 01:44 PM   #258
Problems with Focus and Zoom on 16x Lens
For some reason the 16x lens for my Canon XL-1S camera stopped zooming and became unfocused one day when I turned the camera on. It worked fine just the day before when I used it to videotape a nesting quail hen. Anyway, I was wondering why this lens won't zoom and shows a blurry out of focus image. I was also hoping maybe there was some way to fix this without sending the lens to a repair dealer, which is what I think I'll probably do. I used my 16x lens almsot exclusivley for wildlife and outdoor scenery. I thought maybe it had been jarred too much from me carrying it in a backpack or maybe my brief shots of a setting sun had damaged the lens, though I make sure I never get full-on bright shots of the sun because that can mess things up. Anyway, if anybody has any input on this issue I would appreciate it.
Regards,
Tristan Howard
Tristan Howard is offline   Reply With Quote
Old August 16th, 2006, 09:53 PM   #259
Before getting too excited(I'm sure I would be) you may want to try removing the lense and cleaning the contacts very carefully.If you do alot of outdoor stuff the camera has posibly been exposed to some harsh enviroments and a little clean of the contacts may work.
Jack Smith is offline   Reply With Quote
Old August 17th, 2006, 12:41 PM   #260
Hi Tristan
The same thing happened to my XL1s, the len's wouldn't focus or zoom
Had to send it to canon for repair, the len's was ok but there was a faulty ribbon in the camera what ever that is, but thats what canon said and it fixed it and worked fine
Ian
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old August 17th, 2006, 12:59 PM   #261
Images: 1
They were referring to a ribbon cable. They are typically flat plastic with individual embedded strips of copper that make up the 'wires' in the cable. They tolerate flexing much more than standard cables and because they are flat, they take up less real-estate.
-gb-
Old August 17th, 2006, 01:13 PM   #262
Originally Posted by Jack Smith
Before getting too excited(I'm sure I would be) you may want to try removing the lens and cleaning the contacts very carefully .If you do a lot of outdoor stuff the camera has possibly been exposed to some harsh environments and a little clean of the contacts may work.
I would second this idea. Many years ago I had a Panasonic camera shift all colors to green a few hours before I was to document an important speech. After a couple hours of troubleshooting to no avail I called Panasonic's tech service line (you could actually talk to a tech specialist then). I was advised to remove the lens and clean the contacts. The tech further explained that to save space and weight the metal body of the camera frame was used to carry the negative side of electrical connections (just as automobiles have done for years). Because many components within the camera use such low voltages even a thin film of grime and dirt residue can alter electrical resistance and cause camera components to behave erratically.
Cleanin the contacts and metal faces of the lens mount make the colors return to normal.
If the camra has not been serviced for a year or more, a visit to a repair center would be worthwhile.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old August 17th, 2006, 11:52 PM   #263
Thank you all so much for the useful information.
Old March 1st, 2007, 11:08 AM   #264
Slash Rules!
Stock lens (ISII) back focus fix/lens overhaul cost?
Hello. The to-be-unnamed place where I work has an XL1s that has a fairly screwy stock lens. I don't know if it has other issues, but the back focus is definitely screwed up (won't hold a critical focus). Anyone know how much that repair generally costs?
Old March 1st, 2007, 12:39 PM   #265
Dear Josh,
In case you decide not to fix your XL1s lens, I have a slightly used XL2 20x lens for sale.
Dan Keaton
Augusta Georgia
Old March 1st, 2007, 01:31 PM   #266
Slash Rules!
I'm not the one in charge of the decision. . .I'm thinking if it's a reasonable enough price, I might be able to convince them to have it done. The fixing, I mean.
Old May 29th, 2007, 05:32 PM   #267
Guest
Posts: n/a
Focus Canon xl1s
First of all when i move camera left to right i see a blur when i stop it comes into focus. I see this in the view finder even without recording. i have tried it stab on and off. When i record i get what i see in view finder. I bought the camera used called canon they said no record of service
www.kbvideos.net/blurtest.wmv
Got another wedding june 9th
Old May 29th, 2007, 07:39 PM   #268
go to manual mode, learn to focus by hand...the auto focus is what is doing this to you. Easy mode won't let you focus manually, AF will always be on and annoying you. The more trust you put in machines, the more they will rule your life...Ray Bradbury was sooo right.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old June 5th, 2007, 05:09 AM   #269
Canon XL1 Focus
I have noticed recently that my camera is starting to loose focus even on auto mode. It tends to just breath in and out of focus from time to time.
I haven't had my camera serviced so I am wondering if a service will rectify this problem.
For example what might be causing my camera to loose it's focus like this even in auto mode. I have noticed this on static interview shots I have done even when the talent is center since I understand that when on Auto Focus the camera uses the center of frame as its focus point.
Any suggestions would be greatly appreciated.
Simon Duncan is offline   Reply With Quote
Old June 5th, 2007, 08:26 AM   #270
Auto focus needs reasonably prominent contrasting vertical edges. Drift and focus hunting can be induced by a combination poor light (less than 50 lux) and/or lack of contrasting vertical edges in the focus zone of the image, or if there are changes in the dominant contrasting vertical edges in the focus sensing zone of the image. Any of these could cause auto focus to struggle.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
