Looking for a support device for wireless at DVinfo.net
Old July 27th, 2004, 05:32 AM   #1
I'm currently using a MA-100 to mount my Senn. wireless to the camera. I need an additional support for another camera to keep from changing the mount from camera to camera for other shots during an event. Anyone have any suggestions...I could just go with another MA-100...but I would like to find a more econmical item or find someone with a non-funtioning MA-100.
Mark A. Foley is offline   Reply With Quote
Old July 29th, 2004, 08:51 AM   #2
You've probably already thought of this Mark but you couldn't get much more economical than "hook and loop" tape (velcro).
Randy
G. Randy Brown is offline   Reply With Quote
Old July 29th, 2004, 09:01 AM   #3
I would use velcro if I had a big enough surface area on the cam or evern the tripod head.....
BTW...JVC (Ken Freed) sent me another VS-30 to test...looks like they have a new mod to emllimate the digital glitches....
Will find out after I upload footage after Saturday's wedding I'm doing....
Old August 4th, 2004, 07:25 AM   #4
OT: well?
Hey Mark, did you capture the footage yet...any improvement?
Randy
Old August 6th, 2004, 09:11 AM   #5
Unfortunately no Randy....I believe JVC needs to redesign their the entire 1394 interface of redesign the whole VS-30....
Old August 9th, 2004, 01:40 PM   #6
To Mark and anyone else that has had the problem with the JVC deck, the following is a copy/paste of an e-mail I just sent Ken Freed with JVC:
The problem is not with the deck, it is apparently the "defective" wiring (improper ground) of the electrical source.
Prior to buying the deck I bought a "Master Piece Plus" by Kensington which is a protective power supply for computers. It has 3 LED lights on it: "surge protection", "low voltage", and "wiring OK". The "wiring OK has always been red in color while the rest have been green. I never gave it much thought until my recent relocation move. It is now green and lo and behold the deck captures flawlessly!!!
The old house had some outlets that were only 2-prong; although I was using 3-prong in my editing bay I believe the house was not "double grounded". Now I can't tell you how to fix the problem but I can tell you that this is the culprit and I bet your techs can find a solution with this information. Anyway, I'll bet that if you ask anyone having this problem to go down to the hardware store and buy a circuit checker (or whatever they call it) you'll find that there is no double-ground" (or whatever they call it).
Sincerely,
Randy
