rain, water, cold and the xl1 at DVinfo.net
Old November 7th, 2001, 05:08 AM   #1
RED Code Chef
I know there are protective covers for rain and
underwater housings for the camera. But how
about cold? I live in a country where temperatures
can drop quite low and I was wondering if there
is a "keep-em-warm" kind of case/cover for the
XL1?!?
One other thing.. most of these cases/cover
have a glass window (especially underwater)
for the XL1 to look out from... Does it matter
how good these "windows" are? If so, where
do they sell good one?
Thanks for any help, info or suggestions!
Rob Lohman, visuar@iname.com
Old November 7th, 2001, 06:23 AM   #2
Polar Bear Heated Case
Hi Rob,
Porta-Brace (www.portabrace.com) makes an insulated and heated case for the XL1. It is called the Polar Bear and they claim it has been tested at minus 50 degrees F.
Someone else will have to comment on your glass question, but I would assume that if the enclosure uses a glass piece in front of the lens, it would make a big difference if that glass was of inferior quality.
Ed
Ed Frazier is offline   Reply With Quote
Old November 7th, 2001, 07:22 AM   #3
See this website:
http://www.videosealskins.com/
The Video Sealskin is made for XL1 cold weather use. It has a couple of internal pockets which hold standard hand-warmer packets, available from any camping supplier.
I've used the Sealskin and can recommend it. Only thing is, it rarely gets cold here in Texas. So I haven't exactly tried it out in adverse Artic conditions.
Nathan Gifford bought mine... hopefully he'll put in his two cents about it.
Old November 7th, 2001, 07:42 AM   #4
Hi Chris,
I wish I had known about this product (Video Sealskins) a week ago. I ordered the PortaBrace Rain Slicker with my new XL1S because they are now making one that will cover the MA200. The only similar item I had found was from Kata.
A couple of questions:
How well do you think the Sealskin would keep out dust. My problem here in Southern NM is blowing dust, not rain.
How easy is it to change a tape with the cover in place. I don't see in their pictures any opening in the tape transport area.
Ed
Old November 7th, 2001, 07:52 AM   #5
Hi Ed,
Not to worry as both PortaBrace and Kata make excellent products. I'm sure you'll be very happy with your Rain Slicker.
As I recall on the SealSkin, there are two zippers running the length of the camera along the bottom, one on the left and one on the right. To change a tape involves unzipping the right side and going up from underneath. A little tricky since the tape door opens from the top, but guaranteed to keep the dust and rain out of the transport.
Any of the rain slickers... PortaBrace, Kata, Sealskin... will be very effective at keeping out dust... which is a huge problem here in Texas.
Old November 12th, 2001, 07:47 AM   #6
Retired DV Info Net Almunus
SealSkin
Two questions...
1. Regarding temperature, how low is too low for the XL-1?
2. Does the Sealskin have enough room for the MA-100 with the dual battery holder? And does it have a slot at the hotshoe to allow attaching a light?
Thanks. Temperature's dropping fast here in Seoul. This will be my first winter of shooting since I bought my XL-1.
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old November 12th, 2001, 08:09 AM   #7
John,
I've shot with my XL1 in down to -8. It didn't affect the camera performance but battery performance pretty much sucked. the BP 927's I had lasted about 20 minutes, so keep those buggars warm.
Adrian Douglas is offline   Reply With Quote
Old November 12th, 2001, 08:30 AM   #8
Hmmm...how to keep batteries warm...I'm imagining some pretty uncomfortable scenarios. Better invest in a hand warmer instead, I guess.
Adrian, do you mean -8°F or -8°C?
John Locke
SursumFilms.com
Old November 13th, 2001, 03:21 AM   #9
Celsius mate, so about 24ishF .Wetsuit neoprene works well for keeping battries warm and is also water resistant. Use 5-7mm the trick is finding someone to sew it.
