MA-100 XLR audio adapter questions - Page 6 at DVinfo.net
Old June 11th, 2002, 09:41 PM   #76
kasteede
Posts: n/a
Thanks Chris,
I tried the SP7 at the WEVA Expo last August and although its a nice accessory, I don't think its for me
The style of shooting I do, requires equipment that can be set up and packed up quickly (eg between the wedding ceremony and the cocktail hour) I like the fact that I can fit the XL1 in my camera bag with the MA-100 and wireless receiver attached. I would have to desemble the SP7 before trasporting between venues and this would waste valuable time.
It also never quite felt comfortable to me, although a mate of mine liked the way it felt.
Old June 14th, 2002, 02:34 AM   #77
My MA-100 has a noise problem. This is not uncommon from what I gather. I've spoken with several other XL1 owners around the bay area whom have had similar issues with their MA-100s.
A local pro audio place I spoke with said that it may be a grounding problem and a simple fix may be to construct a ground out of two alligator clips and a piece of wire. Run a clip from the MA-100 and the other to a grounded source and it should take away the noise.
BTW- It has also happened with my Beachtek once in awhile.
Ford Minton is offline   Reply With Quote
Old June 14th, 2002, 06:20 AM   #78
I'm not a "mic" guy, but it's a ElectroVoice n/d 257B dynamic cardioid. XLR mic to MA100. That's it. I'm guessing that maybe it's just low output, but maybe I'm wrong.
John Klein is offline   Reply With Quote
Old June 14th, 2002, 04:38 PM   #79
The MA-100 should be rather quiet. If you are getting high noise, there may be a problem somewhere in the system, perhaps an open ground.
Assuming that the N/D 257 is similar to the N/D 257 ther shoudl be adequate output if the talent is close miked (within a foot or two).
Old June 19th, 2002, 11:55 AM   #80
Mr.Cisco
Posts: n/a
MA-100 question
I have a question regarding the MA-100. There are two XLR inputs and I assumed that I could go from the XLR out on my wireless receiver into one of the XLR inputs and from the XLR out on my shotgun to the other input. Is this possible? If not what do I do? Do I have to go XLR out on the shotgun to the Audio 2 jacks?
Old June 19th, 2002, 02:04 PM   #81
Yes. you can. However, you would do well to have the two sources at about the same level, especailly if feeding it to the Audio 1 input. This minimizes possible issues with level balance between the cahnnels.
Old June 20th, 2002, 07:59 AM   #82
Boss Hog
Mr C.
If you are using an XL1s, you may want to set the "Rec Level"switch to "M" or manual so the camera's AGC is not bringing up a channel that may have its mic turned off.
Your technique is very common. Use the shotgun for Nat. sound and backup audio in case the wireless fails while using the wireless for the Talant's dialoge.
Note: the MA-100 does not provide Phantom power for mics so your shotgun will need to have a battery option (ie: A-T 835b)
Cheers.
"Film is Art; Theatre is Life; Television is Furniture!"
Steve Savanyu is offline   Reply With Quote
Old July 10th, 2002, 11:40 PM   #83
MA100 audio noise
I have a MA100 and it is very quiet, I have used it with ev mics and the Sure SM58, and both were quiet. On "low" output mics, you need to add a Mic pre-amp to compensate, rather than crank up the gain in the XL (which will cause noise.) also turn off the auto level control and set level manually. Keep peaks below "0".
aholston
Al
Al Holston is offline   Reply With Quote
Old July 11th, 2002, 03:28 PM   #84
graphiouz
Posts: n/a
hi
one little question on the side,. do you need the 'sennheiser k6' to run the 'sennheiser ME66 or can MA-100 take care of it?
sorry for this newbee question,.
i need to investigate before i buy both Camera and things to go with it,.:)
tHx
Old July 11th, 2002, 05:21 PM   #85
You do need the K6 to power the ME66 element for use with the MA-100. The K6 allows the use of battery or phantom power.
The K6P requires phantom power and is not suitable for use with the MA-100 unless you have a source of pahtompower.
Old July 11th, 2002, 08:57 PM   #86
The K6 is the best way to go. Allowing you to use battery power when in the field and using on camera, or phantom power when you have it available. aholston
Al
Old July 12th, 2002, 04:53 AM   #87
graphiouz
Posts: n/a
ok thanks guys.
this is a great forum!
Old July 21st, 2002, 01:29 PM   #88
What circuitry, if any, is inside the MA-100 (or 200, for that matter)? Do actually supply a balanced line conversion, or do they simply convert the connectors for convenience?
Charles Papert
www.charlespapert.com
Old July 21st, 2002, 01:53 PM   #89
Unbalanced. Don might know something about what else is going on inside.
Old July 21st, 2002, 03:06 PM   #90
Charles Papert
Charles Papert is offline   Reply
