Thread Tools
Search this Thread
Color Problem
I do most of the weddings in the hotels, I use Canon Xl1s I observed that sometimes the color of the video footage observes blue color more. I asked a technician he told me a story stating that this ntsc xl1s is made for only united states not for jamaica., he means to state that weather condition of usa and jamaica are different. Can anybody help me in this regard. This thing mostly i observed in the mid afternoons. I dont detect when i am shooting the footage. but when i come back to office and start editing iam finding this peculiar thing. Please help me
RED Code Chef
First: are you using an NTSC camera in a PAL country or vice versa?
Second: do you do manual white-balancing? If not, which white balance setting are you using? Any playing around in the camera's custom settings to tweak the color?
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
color
Dear Rob i am using NTSC version of the camera. Mostly all the cameras in jamaica comes from usa. I tried the white balance, I am not saying it always happens , It happens sometimes. The footage looks completely bluish. Especially this happens when i am shooting the weddings in the mid noon. Only some portion of the footage gets bluish, Any way thanx for the reply
vamshi |
Warden
What is most effected, skin tones? I suspect you're encountering effects of increased UV and water vapor, causing a blue saturation to your images. You may need to use a warming filter for your mid day shoots or color correct in post with your NLE.
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
#5 |
hi jeff
I am very thankful for the post.. Mostly we shoot the weddings in the beaches where the moisture level is high, and also the wind. I appreciate the answer saying the warm level filters... Can you please tell what are these warm filters and if possible give me some links..so that i can check the websites. Any way I once again appreciate with the quick reply
vamshi |
#6 |
Try to be aware of what's hitting your white card when you do a manual balance.
If your venue has lots of windows and tungsten lighting, then the position of your card will have a great deal of influence on the final result. Pointing it upward toward the tungsten lights will cause the video to look bluish whenever the window light is prevalent. Conversely, pointing the card toward the window light will cause the video to appear warm when shooting under the tungsten lights. Another factor is the camera itself: when was the last service done by Canon? If it's more than a year or two, it might have to be recalibrated to give you a proper white balance. Dean Sensui Base Two Productions |
#7 |
Warden
Dean, I may be wrong, but it sounds to me like Vamshi is shooting outdoors, not indoors. Most of the major filter manufactures produce warming filters, B+W, Heliopan, Hoya, Tiffen, and Cokin. Warm cards are also an option to alter your White balance. Do a search with the link in my signature or just use Google.
