"Soften Light" Tips at DVinfo.net
Old May 3rd, 2004, 08:31 PM   #1
"Soften Light" Tips
I used XL1-s with on camera light (100WATT) ƒ¼ which is best in some shooting especially in dark condition, problem arise when during the interview shot, many complain from interviewer ¡§Your light is too annoying¡¨ when I point the light to them.
Any idea how to soften light in low budget way ¡§home made¡¨ or ¡§DIY style¡¨?
Suggestions please
Andrew
Andrew Kiu is offline   Reply With Quote
Old May 4th, 2004, 11:22 AM   #2
Break out the sunscreen!
100 watts for an on-board light it pretty hot. I have an Anton Bauer Ultra-Light 2 on my XLs and never go over 50 watts at most. I usually use a 25 watt lamp in the unit, and even that is pretty strong when doing up-close interviews.
If you can't change the bulb, then I would suggest using a few layers of spun or some other type of diffusion to cut down the wattage.
Failing that...offer your subject some sunglasses! :)
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old May 5th, 2004, 03:51 PM   #3
I believe frezzi makes a soft box for just such a problem it's basiclaly a many chimera and takes a lot of the edge off of the subject when shooting them.
Nick Hiltgen is offline   Reply With Quote
Old May 5th, 2004, 06:19 PM   #4
Thanks guys if i plan to buy new "on Camera Light" which brand recommended? frezzi or Anton Bauer ultra light? any other? Low budget! long term usage and value for $....
Andrew
Old May 6th, 2004, 05:02 PM   #5
Frezzi, but only because I haven't used the anton
