Windowburn | Timecode to VHS at DVinfo.net
Old April 21st, 2004, 02:38 PM   #1
Hello,
I'm trying to export directly from the XL-1s to a VHS cassette with the timecode.
I'm trying to keep my raw footage on the mini DV tape pristine, and use the VHS to log the timecodes of sections i want to capture.
In Canon's manual, the EVF button seems like it's supposed to enable this, however, nothing happens when I press the button.
I'm in the XL-1s' VCR mode and see the timecode in the viewfinder. But the image on my TV monitor does not show the timecode.
Does anyone know how to do a windowburn to a VHS cassette/make the timecode show up on the VHS worktape?
Any help would be greatly appreciated.
Therese Kim is offline   Reply With Quote
Old April 21st, 2004, 07:22 PM   #2
With the XL1, you press the "On Screen" button on the remote. The XL1s may have the same functionability.
dpalomaki@dspalomaki.com
Old April 22nd, 2004, 07:51 AM   #3
I called Canon before I read your post, and they told me the same thing you wrote. It does work.
Canon tech support says you should be able to get the timecode to show up on the TV monitor through the "onscreen button" on the remote and with the "TV screen" on the camera. I never got it to work through the camera's menu -- just through the remote.
Thanks again for your help-
Old April 23rd, 2004, 05:09 AM   #4
RED Code Chef
It will ONLY work through the remote. There is no such button
on the camera itself. There is an info detail toggle button on the
camera, but that is for information in the viewfinder while recording.
Rob Lohman, visuar@iname.com
Old April 23rd, 2004, 07:40 PM   #5
There is a "TV SCREEN" button on the WL-D73 remote that came with the GL1.
Old April 26th, 2004, 01:56 PM   #6
Thank you all for responding -- it's been helpful to read your comments.
Old June 7th, 2004, 07:12 PM   #7
You may NEED the remote with the XL1 to accomplish this, but that is not the case with the XL1s.
On the XL1s, you can indeed get viewfinder information to be passed to a monitor - under the 'DISP. SET UP' part of the menu, choose 'TV SCREEN' and turn it ON or OFF.
This is exactly how I get all the viewfinder info to pass to my mounted LCD monitor.
-Ken
Ken Saltzman is offline   Reply With Quote
Old February 10th, 2005, 09:06 AM   #8
Hello :-)
Did you check this??
If you get the info to display on-screen, it doesn't record on the tape, it is for operational purposes.
Please correct me if I am wrong, but that is how I read it and have used it numerous times. I don't think the XL1 has any option to burn timecode, the XL2 on the other hand does. I own both, but never needed this feature, so I could stand corrected.
I would be interested in your results :-)
AM
Anthony Marotti is offline   Reply With Quote
Old February 11th, 2005, 11:15 AM   #9
The timecode burn-in function is called Character Record.
It is not available on the XL1. It is available on the XL1S and XL2.
Old February 11th, 2005, 12:57 PM   #10
Hi
That's what I thought, I however did not know about the XL1S :-)
AM
