16X Manual Lens Questions - Page 2 at DVinfo.net
Old December 28th, 2001, 08:45 PM   #16
I just got my Canon 16X manual lens What a GREAT Lens.
Mark Chiocchi
Franklin Township, N.J.
DpsVelocity Editor
XL1S & GL1
Mark Chiocchi is offline   Reply With Quote
Old August 7th, 2002, 09:16 PM   #17
16X Manual Servo Lens - Focus Question
I recently purchased the 16X Manual Servo Lens. Great lens but I am having trouble getting a really sharp image. I am sure that it is due to my inability with it. My viewfinder is color, which I think might also be part of the problem.
Do any of you old pros have any suggestions on how to insure a sharp image/shot?
Paul Sedillo
Image::Studio
http://www.image-studio.com
Houston, Texas
Paul Sedillo is offline   Reply With Quote
Old August 8th, 2002, 03:51 AM   #18
Slash Rules!
Hello, fellow Houstonian. I have that lens, and perhaps you need to adjust the back focus? I have no problems getting a sharp image with this lens when focusing with the color viewfinder, whereas I did before with the ISII.
Anyway, if your back focus is screwed up, it could be throwing your focus off. Unscrew the. . .little screw near where the lens meets the body, and when you're zoomed all the way wide, focus by rotating the ring with the little "m" button, then, carefully (so as not to accidentally turn the ring) screw the screw back in.
I know all these little pieces and parts have technical names, but I'll be damned if I remember them at five in the morning.
If this is not your problem, forget you've read the last three paragraphs.
Old August 8th, 2002, 03:56 AM   #19
Josh,
Thanks man! And what the heck are you doing up so early!!
I will give your suggestions a try today. Supposed to shot a short this weekend, so I worked out this issue.
Last weekend I shot a mountian bike clinic over at Memorial Park. This is the footage that is not as sharp as I would like.
Paul Sedillo
Image::Studio
Houston, Texas
Old August 8th, 2002, 03:57 AM   #20
Warden
Search the term back focus and you should be able to find several threads covering the complete procedure for adjusting back focus. It might even be covered in an article on the XL1 Watchdog.
Jeff
Old August 8th, 2002, 04:02 AM   #21
Slash Rules!
Yeah, what he said. My procedure's correct, but there's a more technical one. I left some stuff out. . .my fault. Be sure to critcally focus the regular way on an object 75 feet away, or whatever the farthest away you can focus (bad grammar).
After that, do the whole shebang I told you about.
And it's not up early, it's up late.
Old August 8th, 2002, 04:06 AM   #22
Thank you Josh and Jeff. I just found the thread via search that covers this. It was a thread the Josh posted. Very informative stuff:
http://www.dvinfo.net/conf/showthread.php?s=&threadid=2333
Paul Sedillo
Image::Studio
Houston, Texas
Old August 8th, 2002, 11:24 AM   #23
Slash Rules!
Yes yes thank you thank you . . .oh you're too kind. . .no I don't do autographs.
Old August 8th, 2002, 02:26 PM   #24
Josh,
Now my question is did you coach Vin Diesel in his latest quote (which I love):
"People keep asking if I've changed since becoming a celebrity. But I haven't changed because I've always thought I was a celebrity. It was the rest of the world that hadn't figured it out."
Paul Sedillo
Image::Studio
Houston, Texas
Old August 8th, 2002, 02:58 PM   #25
Slash Rules!
No. Ick, Vin Diesel.
Old September 24th, 2002, 07:33 PM   #26
manual 16X
I read where the manual 16x lens does have a power zoom capability. Who sells something that would make this work? Would it be for tripod use only or could you somehow use the existing zoom control?
John Dimasi is offline   Reply With Quote
Old September 24th, 2002, 10:42 PM   #27
Jonathan
The 16x lens power zoom works with the xl1s zoom control via a motor mounted on the lens. There is a switch on the bottom that allows a choice of full (mechanical) zoom, or servo, so in servo it works essentially the same as the auto lens, without the autofocus.
Barry
Barry Goyette is offline   Reply With Quote
Old September 25th, 2002, 09:44 PM   #28
Barry,
So your saying the existing zoom control on the Xl-1 will work with the 16x manual lens without any wiring or extra parts and pieces?
Old September 25th, 2002, 10:34 PM   #29
True plug n' play my friend. Just mount it and forget it. Just make sure you flip the switch if you decide to go manual.
Barry
Old September 25th, 2002, 10:46 PM   #30
Also, any LANC remote lens controller, such as the Canon ZR1000 or any VariZoom LANC model, will remotely control zoom on this manual lens. Not focus, though... that requires a separate VariZoom focus controller. Hope this helps,
Chris Hurd is offline   Reply
