Using a Xl1s for live feed at DVinfo.net
Old April 13th, 2004, 06:15 PM   #1
Can I use my Xl1s as a camera used for live feed?
i.e. for filming a live event? If so do I need any special cables or attachments?
thanks,
zachster
Zach Turpin is offline   Reply With Quote
Old April 13th, 2004, 07:00 PM   #2
Sponsor: JET DV
Yes. We do it every week. We have two XL-1 cameras connected via S-Video to a video mixer which is connected to a deck which is connected to a computer. We can actually capture the event into the computer live.
Old April 14th, 2004, 05:27 AM   #3
I shot a kick-boxing match about a year ago that required a live feed from my XL1S to a video projector that was hung from the ceiling of the arena. About 30 minutes before showtime, I discovered a 60Hz hum in my audio and couldn't figure out where it was coming from. All audio connections were disconnected, but it was still there.
It turned out to be coming from the video out to the projector. Fortunately, one of the other camera operators was a tech for a local TV station and realized that I needed a video isolation transformer to fix the problem.
He made a quick run to the TV studio to get one and arrived back just in time for the start of the show.
I had all sorts of audio adapters and transformers in my kit, but noting to solve this problem. I now carry a video isolation transformer as well.
Ed Frazier
Ed Frazier is offline   Reply With Quote
Old April 14th, 2004, 07:21 AM   #4
We also do this all the time, three cameras into a switcher.
The only special thing you need to do is to set your camera head to remain on at all times. If you don't and are not rolling tape, the camera will shut down taking the picture with it.
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old April 14th, 2004, 04:12 PM   #5
thanks for the info, I am used to using the camera but I have never used it in this way before. I am on my way down to Equador, and one of the things that needs to be done is to video a inauguration live so i am just trying to figure it all out. Any more info is appreciated,
zach
